Old 07-19-2017, 07:23 PM   #1
jbirdbobio
1978 c20 to 1976 k10 cab
found a nice cab from 1978 c20 will it fit with 1976 k10. doors, hood are much nicer than I have.
jbirdbobio is offline   Reply With Quote
Old 07-19-2017, 10:03 PM   #2
70K10Hunter
70K10Hunter's Avatar
Re: 1978 c20 to 1976 k10 cab
it should fit, Is your cab unuseable? why not use just the doors and hood from the 78 on your cab?
70K10Hunter is offline   Reply With Quote
Old 07-20-2017, 08:58 AM   #3
Tash4
Tash4's Avatar
Yes the cab will fit , but the hump or trans tunnel is taller on the 4x4 to clear transfer case. some unbolt on the older ones so you might be able to swap covers.
Tash4 is offline   Reply With Quote
Old 07-20-2017, 07:33 PM   #4
jbirdbobio
so the cab is the same but cover from 76 would make up the difference in height
