10-25-2003, 02:12 AM | #1 |
ran out of money
will any 400sb fit a 700r4?
Hello all
I found a 400 small block out of a Pontiac and I was wondering if the bolts pattern and everything for the bellhousing to bolt up is the same as a chevy's? Thanks for all the input.
Modify everything, leave nothing alone!~ |
10-25-2003, 03:51 AM | #2 |
i do believe BOP (buick/olds/pontiac)(cadillac too) motors had a different bellhousing pattern than chevies.
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
10-25-2003, 05:15 AM | #3 |
I think that is correct. The pontiac 400 will not bolt directly to a 700r4. I think if you find a 200r4 you will be in luck. I think that trans has both bolt patterns.
Just sitting here contemplating contemplation. |
10-25-2003, 06:57 PM | #4 |
cadillac i thought had the same boltpattern bc they used the turbo 400 on some of their big blocks I THINK
70 longbed 496/th400/Ford 9" |
10-25-2003, 08:24 PM | #5 |
Watch out for your cornhole !
Buick, Olds, Pontiac, and Cadillac used a seperate pattern than Chevy. Some trannys, particulary lots of 200-4r were dual drilled for either pattern.
Dinnut, sure Caddy uses TH400, but it's different bolt pattern than Chevy.
10-25-2003, 09:25 PM | #6 |
PROJECT 7DEUCE
b.o.p. motor's did have different bolt pattern's for sure... The internal part's from one trannt to the other will inter change though.. So at least you could find a b.o.p. tranny and swap the gut's with a chevy tranny to make it all work.
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
10-25-2003, 11:41 PM | #7 |
They make B.O.P adapter plates that go to Chevy trans. They cost around 80 dollars. I believe that Summit or Jegs carries them.
69 Chevy Truck, 350, 400trans, Lowered 3.5/6, Disc brake conv, All early classic stuff. 62 Chevy Nova 350, 700R4, 2400stall, F9in, 3.70gear, AlburnPosi, Chevelle Disc Brakes, ect. |
10-26-2003, 03:23 AM | #8 |
adaptor plate
right guys they make a plate to adapt things,but my uncle had a 69 or 70 chevy truck a few years back that had a rare tranny In It that would accept bolts of chevy and buick olds and pontiac on the (hogs head)bellhousing.they did not pmake alot of these this way just a few.
