07-19-2017, 08:39 PM | #1 |
Fuel Sending Unit Ground Location?
Hello all,
Wondering if someone could help me out with this. I purchased an took over a friend's project. 1972 C-10. The previous owner had already mounted a new aluminum bed mount fuel tank. The sending unit which is already installed does not have a separate mounting point for the ground. My questions are: 1. Does it need a ground or is the tank bolted to the frame the "ground". 2. Should I install a ground wire beneath one of the 5 bolts on top of the sending unit as seen in the pic? or 3. Should I put the ground on the same mounting point as the sending unit wire beneath it. Thanks in advance for any help. |
07-19-2017, 09:09 PM | #2 | |
The Older Generation
Re: Fuel Sending Unit Ground Location?
If the tank is mounted on rubber pads or straps with isolators you will need to use a ground wire. If the tank is bolted directly to the frame you may or may not have a ground, depending on how much paint is on the frame. I would just run a ground wire to one of the mounting bolts (between the tank and the head of the bolt) and clean the paint off around a hole in the frame and bolt it up. LockDoc
07-19-2017, 09:18 PM | #3 |
That's what I was leaning toward sir, just wanted some input from someone with more knowledge than me. Thank you
07-19-2017, 11:33 PM | #4 | |
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
07-20-2017, 09:18 AM | #5 |
Old member
Just for good insurance run a wire off one of those mounting bolts over to a bare spot to the frame. This way you know you have a good ground.
07-20-2017, 09:19 AM | #6 | |
Not really. I just went through this yesterday on my '36 Ford Coupe. Whenever you are grounding to an area that is powder coated or a couple of coats of POR15 you cant rely on the grounding (internal and external star washers) to bite through it to bare metal. I removed the POR15 on the areas of my frame where I bolted the ground straps. I still use the star washers, but I want the metal clean. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 07-20-2017 at 09:29 AM. |
07-20-2017, 02:29 PM | #7 | |
