07-20-2017, 12:46 AM | #1 |
Need help (pics) Identifying parts
Can anyone help me identify these parts? The plastic piece inside the cowl and whatever is coming out from it. close up pics of inside the cowl would be super helpful. Thanks
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612 Build version 2.0: 72 K5 6.0 LQ9, 4L80e, NP205 http://67-72chevytrucks.com/vboard/s...d.php?t=793192 ____________________________________________ 1972 CST K5 Blazer Dark Olive |
07-20-2017, 01:11 AM | #2 |
Re: Need help (pics) Identifying parts
I submitted this in my build thread but hoping to find help asap.
The Factory Assembly Manual refers to the L Shape tube as a "shaft" (#21) in the diagram. I found the metal piece ( also referred to as crank from others on here) that slides into the shaft and attached via a screw. (#3) "Cap" and (#4) "Bearing" stated in the diagram is where I am lost. The Spring (#2) Looks like it attaches to the top side of the cowl and the other end connects to something, I have no idea what, shown here in the diagram (#1) Valve ASM at the bottom right corner. What does this "Cap" (#3) look like? Is it available? Are there alternative options? What about the "Bearing" (#4) Is it available? Are there alternative options? Appreciate any help from the board. Thanks!
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612 Build version 2.0: 72 K5 6.0 LQ9, 4L80e, NP205 http://67-72chevytrucks.com/vboard/s...d.php?t=793192 ____________________________________________ 1972 CST K5 Blazer Dark Olive Last edited by 72K5CSTDarkOlive; 07-20-2017 at 02:14 AM. |
07-20-2017, 07:31 AM | #3 |
I have a few pictures I can post tonight. Not the greatest should have taken better ones. I should have everything you need if you don't have it.
07-20-2017, 08:44 AM | #4 |
I also can take some pics for you tonight. I'm currently putting my A/C back together as well.
Eric |
07-20-2017, 09:35 AM | #5 | ||
@1rippen - I'm not entirely sure which pieces I need. I know I don't have the ones I mentioned above, (Cap, Bearing, Spring) but there could be other parts, but without knowing what I'm looking at I don't know. And whatever goes in those two holes in the cowl (Dash side) pictured above. I'll need these too. Thanks guys
07-20-2017, 10:02 AM | #6 |
07-20-2017, 02:23 PM | #7 | |
07-20-2017, 02:34 PM | #8 |
Yep, should have everything off that rough jimmy I just scrapped.
07-20-2017, 03:23 PM | #9 |
PM Sent
