Old 07-20-2017, 07:23 PM   #1
1969 Project
1969 Project's Avatar
Power Steering fluid seepage
I changed my power steering lines last week because they were leaking from the flare seal. No more leaks from the flare but I am getting a little seepage from the threads now. I know you can put thread sealant on the intake bolts to stop the oil seepage from the bolt threads.... is this something that I can also do the threads for the PS lines? It seems like every time I get something fixed on the truck something else decides it also needs to be fixed.... funny how that works!
1969 Project is offline   Reply With Quote
Old 07-20-2017, 08:17 PM   #2
jeffahart
jeffahart's Avatar
Re: Power Steering fluid seepage
If it's leaking from the threads it's leaking from the flare. When hot, back it off a bit then re-cinch it. Should be good.
White K20
jeffahart is offline   Reply With Quote
Old 07-20-2017, 08:20 PM   #3
dennislbrooks
dennislbrooks's Avatar
x2 --- If it still leaks, examine the flare and the ball it compresses against.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T
dennislbrooks is offline   Reply With Quote
Old 07-20-2017, 08:26 PM   #4
1969 Project
Thanks guys, i'll give it a try.
