Old 10-25-2003, 08:36 AM   #1
69C10Atl
Trying to stick with it
69C10Atl's Avatar
Pics and question on p/s?
hey all here are some pics of my truck as it sits, slowly coming back together.
69 Chevy C10 LWB somewhere in the pile of parts in my garage.
01 Cadillac STS as daily driver
69C10Atl is offline   Reply With Quote
Old 10-25-2003, 08:37 AM   #2
69C10Atl
69C10Atl's Avatar
another of the interior
Old 10-25-2003, 08:38 AM   #3
69C10Atl
69C10Atl's Avatar
so what have I done wrong with the powersteering pump, it interfers with the alternator bracket
Old 10-25-2003, 08:39 AM   #4
69C10Atl
69C10Atl's Avatar
another
Old 10-25-2003, 08:45 AM   #5
69C10Atl
69C10Atl's Avatar
What i've done to the truck so far
-removed rusty core support and inner fenders
-installed power steering gear
-trying to install pump
-new motor mounts
-new oil pump and oil pan had big leak
-rebuilt HEI with petronix kit
-installed new intake manifold gaskets
-installed new Edelbrock performer carb
This is not s restoration attempt just trying to make a dependable driver for now. I'm gathering tools and parts for a frame off in the next couple of years. I may keep as daily driver and find a 67 short step for project.
Old 10-25-2003, 09:52 AM   #6
cwilli84
1FINE69
cwilli84's Avatar
I looked at mine (on a 350zz3 block)with power steering and the top bracket does not mount off the waterpump, and it connects to the backside of the pump. This being a replacement motor setup by a previous owner I'm not sure what all was used to do it but I would look into moving or replacing the upper bracket , especially if the original belt isn't tight yet or if you plan to replace it use a longer one to move the pump top to the outboard side more. It would seem very possible but may have issues with reading the correct fluid level or leaking out the top. I can try to get pictures soon as I have other issues that are causing me troubles and have the front part of the motor exposed, which makes it easier to get a shot of it.Let me know if you want some pics I'll try to get some of it.
Had a 69 swb fleetside 350zz3 w 400turbo trans oak lined bed with rhino coated sides red exterior. SOLD
cwilli84 is offline   Reply With Quote
Old 10-25-2003, 09:57 AM   #7
cwilli84
1FINE69
cwilli84's Avatar
Also from looking at the pics could you use what looks like alternate mounting hole to move it down and out. It looks like more holes at the 9oclock position andthat would put it lower and out more and the uppshould be able to stay where it is just swivel at bit and slide out to acccomodate the new lower/O/B position. Just some thoughts.
Old 10-25-2003, 10:56 AM   #8
69C10Atl
69C10Atl's Avatar
Thanks I'll try that. oh yeah some pics would be most helpful
Old 10-25-2003, 11:45 AM   #9
Hotrodhenryj
Truck Farmer
Hotrodhenryj's Avatar
You have the wrong bracket to mount the pump. Here is a pic of the correct one.
Arizona rust free sheetmetal
Hotrodhenryj is offline   Reply With Quote
Old 10-25-2003, 11:47 AM   #10
Hotrodhenryj
Truck Farmer
another
Old 10-25-2003, 12:02 PM   #11
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You have the wrong type of brackets. See pics:
Old 10-25-2003, 12:08 PM   #12
Tx Firefighter
installed on truck:
Old 10-25-2003, 12:59 PM   #13
69C10Atl
69C10Atl's Avatar
I've got several pumps in the garage from different chevy's, i"ll look and see if I have that bracket. Thanks
Old 10-25-2003, 01:41 PM   #14
69C10Atl
69C10Atl's Avatar
Nope I don't have that bracket, guess I'll look on the parts board for one. I got the bracket in the pic from CPP come to find out from them in their tech article they even say it won't work. Nice considering its the one listed for a 69 chevy.
Old 10-25-2003, 06:14 PM   #15
Linus0014
Guest
Posts: n/a
I dont have those correct brackets either. I had a set of brackets that are "off th wall to me" when I got my 72 GMC. I have never seen them so thats why. One of them mounts to the left side manifold bolts to the left of cylinders 2 and 4. Could it be that it was to have the Alternator mounted on left side of engine? B/C I used a different motor where it mounts to the right side. Does anyone have a set of brackets (power Steering) that are correct and want to sell?
