2 chamber master cylinder.
I am keeping my drum brakes on my 63 but want to put a 2 chamber master on. Does anyone know what will bolt up and do I need to modify the push rod? Thanks
![]() Join Date: Oct 2006
Re: 2 chamber master cylinder.
This should help you :
http://67-72chevytrucks.com/vboard/s...ighlight=split great write up on how to do it
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
I used a NAPA #NMC P1880 on my 63 with drum brakes. Did not make any adjustments to push rod.
Joel |
60-66 Nut
![]() ![]() Join Date: Mar 2007
A '67-'70 C10 master cylinder will work just fine.
