Old 07-21-2017, 10:53 AM   #1
Dwolfe
1965 stepside rear end swap help?!
Alright guys so i recently installed my choppin block rear and awhile ago picked up supposedly a ford 2002 expedition 8.8 3.73 posi rear i measured the width and checked out thought i was set but now that im looking at it i cant seem to get it to line up right and straight? Am i doing something wrong? My truck had a newer 10 bolt 7.5 and its not going to hold up to the 5.3 ls i got i dont think. I still have it if it will? Any help? Heres are some pics
Dwolfe is offline   Reply With Quote
Old 07-21-2017, 12:06 PM   #2
Dwolfe
Re: 1965 stepside rear end swap help?!
More pics
Old 07-21-2017, 12:23 PM   #3
The Rocknrod
Moderator
The Rocknrod's Avatar
Is the pinion offset or centered?
Old 07-21-2017, 12:25 PM   #4
Dwolfe
Honestly i have no clue ... first time doing this haha how do you tell?
Old 07-21-2017, 12:29 PM   #5
Dwolfe
Hers a few more pics
Old 07-21-2017, 01:03 PM   #6
The Rocknrod
Moderator
Watch this video first - https://www.youtube.com/watch?v=bME08UU4Chc
Old 07-21-2017, 01:27 PM   #7
Dwolfe
Yesh i dont think my rear is going to work , guess i bought one with a offset . What would be a good rear ? 12 bolt? I dont think the 10
Bolt wil hold. I have a 5.3 ls thats going in it
Old 07-21-2017, 01:48 PM   #8
RKO
The later large 8 3/4 10 bolt will hold up just fine. There are guys drag racing with them with a lot more HP than you and they hold up fine. I think the pinion dia is the same as the 12 bolt
RKO is offline   Reply With Quote
Old 07-21-2017, 05:04 PM   #9
Dwolfe
What does that rear end usually come in?
Old 07-21-2017, 05:07 PM   #10
Dwolfe
And this is a 7.5 right?
Old 07-21-2017, 09:02 PM   #11
RKO
Get one out of an early 90s impala they will have disc brakes and the same width as stock 66 rear end along with 5 on 5 bolt pattern. Station wagons have the same rear end but are the same width as 80s pickup. Also heavy half 81 to 86 pickups
Others will know more. I'm going off my memory so do a little research ok I could be off on measurements
https://www.gmbbodyforum.com/t333-ho...8-5-8-75-8-875
Old 07-21-2017, 09:13 PM   #12
RKO
Sorry I'm not that good at rear ends. Pop the cover and measure
I had some police impala from the 90s but the race guys have taken all the rear ends
I do have one disc brake set up for them left.
Old 07-21-2017, 09:31 PM   #13
RKO
Dam spell check that should be eight and a half
Sorry about that
Old 07-22-2017, 12:13 AM   #14
Dwolfe
is all great! thanks for the help! I'm going to the yard tommorrow will let you guys know what i get!
Old 07-22-2017, 11:50 AM   #15
Dwolfe
Update! Scored a 67 c10 rear end fits perfect , its a 12 bolt with 3.73 gears, are all new just needs new brake hardware. 150$! Back to the welding now
