07-21-2017, 03:22 PM | #1 |
AC Vents dash installation 66 C10
Made progress today...moved my ac vents from under dash to dashboard.
Used a 2 1/2 inch hole saw. The vents I used are from Vintage Air I drilled a 1/4 inch hole first in correct location. I removed the regular bit from the hole saw and used a cut off 1/4 inch bolt so not to enlarge the bit hole and make the saw try to wander. The slower the saw turns the better...will not grab and do damage. I used a tootsie roll in die grinder to do the final opening. It is really easy with a carbide bit to gouge. Since I already have the factory center vent I think it makes a much cleaner look than the vents hanging under dash. |
07-21-2017, 03:27 PM | #2 |
Moderator
Re: AC Vents dash installation 66 C10
Looks awesome!
Thats my plan when I get there. Hopefully the tri-vanes are the same size. And your gauge panel looks great too.
07-21-2017, 03:34 PM | #3 |
Thanks...appreciate the comment!
07-21-2017, 05:02 PM | #4 |
I'd like to know more about the vents. Do they open and close or just rotate? Do they turn 360 degrees? Is the trim bezel ample enough to provide a bit of coverage in case the hole gets a bit out of round? And lastly, do you have a part.# for those. I want to do the same deal and have been looking at them on the net, but it'd be nice to have a first hand report.
07-21-2017, 06:50 PM | #5 |
Looks nice! Been thinking of doing this too. Do you have the factory AC or aftermarket? I have factory and I haven't decided the best way to branch off the factory duct work.
07-21-2017, 10:38 PM | #6 | |
sand paper rolls in the die grinder after drilling the hole so not to remove too much material to make it fit snugly. I don't have a part number but there are many different vents you can get from vintage air or old air products..if I were buying new ones I would get the triple vein...mine are the dual. I think this is the vintage part number but don't hold me to it (Louver 490535) If you do this be sure to use a dial caliper..not a tape measure...good luck! |
07-21-2017, 10:45 PM | #7 | |
adapter for the center vent to improve air flow. I have to do some wiring before I get to that point. Here is how to contact to get the vent. |
07-22-2017, 12:39 AM | #8 |
60-66 Nut
Just a FYI: Corvette Jim does make individual side vents that are the same design as the center vents.
07-22-2017, 01:45 PM | #9 |
