Cruise control wiring
My 86 C10 has cruise control but when I went to check the lever it only had about a 6" harness with a small blue square plug on it and t wasn't plugged into anything. I have ordered a replacement lever to come next week and it shows as a fairly long wire with the flat plug on the end of it but I don't know where it should plug into. Any ideas or photos of the correct lever, wiring, plug and where it plugs in.....TIA
Re: Cruise control wiring
First you have to know what option your truck has on the column. What wiper motor w/pulse or wo/pulse, what year Column in it now. w/tilt wo/tilt, w/cruise or wo/cruise.
Then check the column lower near the ignition switch (not the ignition switch cylinder key) The wire runs down the in side plastic column cover.
![]() Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
It is a 86 column with pulse wipers, tilt wheel and cruise control. I have looked at the lower end of the column mast jacket but don't see a plug that looks like it will accept the wires from the cruise lever. Only thing that could be possible is the brake light switch.
The first pic is the lever that I took out of the truck and the second is the replacement. Can anybody tell me for sure which is the correct one for my 1986 C10 with tilt, pulse and cruise? And secondly, I don't see any harness at the bottom of the column for this to plug into. Any chance somebody would have a photo of where it is plugged in?
Greatly appreciated |
Persistence pays off. It was the second pic arm that is correct. Kept searching and found a plug buried up in the harness. Now have working cruise and pulse wipers after changing module.. truck just keeps getting better and better
![]() Join Date: Oct 2014
Glad you found it. I was reading this post and was going to say it was the 2nd pic. I have an 86 and this was the correct part. And that the connection was under there somewhere. But I knew where mine was, because of taking it out and putting the new one in. I could have gotten a pic for you maybe, it is kind of hidden under the vent tube for the A/C.
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
That's another thing I am missing is that lower tube. I believe it is available so only have a/c on upper vents right now. Not 100 % where it goes but once I get a replacement it shouldn't be too hard to figure out.
#8 | |
I thought I have seen them new, here's one place: http://www.classicparts.com/1973-87-.../#.WYItmK3Myi4
OK little different than I thought. Have to go take a look at my buddy's 87 see how it hooks up.
Thanks for the link. |
