![]() Join Date: Mar 2003
***More AC questions***
Redoing the big block in my 69 GMC flatbed. Putting in a semi-built 454. Nothing radical, but should be a clean 350+ hp. Anyways, while the engine was out I pulled the evaporator box apart, cleaned it out and installed a newer unit where the receiver/drier hangs with thoughts of upgrading the unit to a cycling system and 134a. Already have the new condensor mounted. Where I am at now is getting a compressor and getting it mounted while the engine is on the stand for mock up purposes.
An R4 would be the easiest for placement along with not needing an extensively long belt, but I know it's a so-so compressor. I was also looking at the Sanden style, but that would require the unit hanging over the valve cover and maybe require an idler pulley to stop the belt from flopping under load. Any bracket kits available? What say you? Of course this is V belt driven |
Re: ***More AC questions***
I have had good success with the R4 on cars and trucks.
http://67-72chevytrucks.com/vboard/s...d.php?t=698292 |
Yeah, I haven't had too many problems with the newer rebuilds like I used to in the past. A serpentine system would be sweet with the short water pump system. I looked into that, but it would require quite a bit of fabrication that I just don't have the time for at the moment.
Bumping this to the top for the Monday crew
Wow, nobody?
![]() Join Date: Aug 2004
I did something similar with my old 68 BBC truck. Used square body a/c parts and a Sanden compressor on Alan Grove brackets. It put the compressor over the valve cover, but I was ok with that. No pics handy right now since PB changed their game.
The belt did fine, it was long but not any longer than the factory setup as I recall. No problems with slipping or anything. I got and re-sold a factory serp setup for that truck, it was from a 90s 454. I contemplated moving the engine back to get it to work, and I'm not sure what kind of valve cover clearance that would have allowed. Probably none.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
#7 | |
Old member
![]() Quote:
Several compianes are making these this is just one. Brackets put everything up front below the valve covers. ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Maybe just install a 90s factory serpentine belt system?
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
The long water pump is too long. It's almost "feeler gauge" distance between the pulley and radiator. There's not a lot of clearance with the factory setup short pump. I had to offset mount the Lincoln MK8 fan I used on mine for the motor on the fan to clear. That's after I trimmed the MK8 fan shroud a fair amount.
I would have loved to have used that serp setup I had.
