Old 07-24-2017, 12:23 PM   #1
JMD
JMD's Avatar
Throttle cable binding, suggestions?
Hi all,
Finally got my '68 k10 big block project on the road and now I'm trying to work the bugs out of it. One of the issues is that the throttle cable has a pretty severe bend in it making the gas pedal stiff and low speed maneuvering difficult.
Here is my current set up: Lokar pedal assembly, cheap off brand throttle cable, and an Edelbrock intake manifold, carb, and throttle bracket on top of a 454.
I have a few ideas in mind, but I'd like to hear what you guys think. I'm sick of accidentally chirping the tires at every intersection!
JMD is offline   Reply With Quote
Old 07-24-2017, 01:53 PM   #2
demian5
demian5's Avatar
Re: Throttle cable binding, suggestions?
I don't see that pedal on the lokar site. Maybe it was disco'd for a reason?
I would think there would be more cable sticking out of the housing inside of the vehicle. Looks like at closed throttle, the cable end is hitting the cable housing mounting. But you can't add cable...
Lube the crap out of it?
Find a better cable that has a sleeve?
Maybe change the position of the pedal so you have more working leverage - I think you can index the lever and pedal differently right?
Add a stiffer return spring if its hanging the throttle open?
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 07-24-2017, 03:59 PM   #3
68is4me
68is4me's Avatar
Might be your cable is it sleeved? I have the same setup but using the lokar cable it moves like butter. The offset I have is about the same as you.
68 c10 swb stepper
68 c10 swb stepper
67 c10 lwb
06 gmc duramax
68is4me is offline   Reply With Quote
Old 07-24-2017, 04:02 PM   #4
kwmech
Longer cable and loop it?
Old 07-24-2017, 04:17 PM   #5
JMD
JMD's Avatar
I don't think it's been discontinued, part number is XBAG-6164
Are throttle cables supposed to have a plastic sleeve? I don't believe my cable has a sleeve (Like I said, it was cheap).
As I look at other member's setups, it seems like a bend like that is pretty normal. In fact many have a much more severe "S" curve and it still seems to work fine...Maybe I just need a better cable?
Old 07-24-2017, 04:25 PM   #6
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Throttle cable binding, suggestions?
The cable should have a plastic sleeve and a Teflon sleeve. Mine works fine.
The small cable inside the S/S sleeve is grabbing the sleeve. I would buy a new cable and it should be fine.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 09-21-2020, 02:38 PM   #7
Rookiebuilder
@ JMD said "I don't think it's been discontinued, part number is XBAG-6164". That is a Lokar product that is available from my understanding. I was on the phone this morning with them talking about the 6164 product and they had it. My question is what throttle mounting bracket are you using because lokar said they do NOT have one (throttle mount bracket) for a TBI setup to go with the XBAG - 6164 assembly.
Thanks for your help!
Eric
Rookiebuilder is offline   Reply With Quote
