Old 07-24-2017, 08:48 PM   #1
Cheyenne350
Dirty dingos mounts
Currently working on a 78 short bed 2wheel drive with a ls1/4l60e equipped with dirty dingos engine sliding plates. My question is how far back did you guys go if your using these plates? My stock driveshaft fits well but I see from my yolk that I could go further back more, and on the plates I see little more room to play with so slide back. Thank you guys in advance... also added a picture of the passenger side plate
Cheyenne350 is offline   Reply With Quote
Old 07-25-2017, 09:35 AM   #2
Hart_Rod
Hart_Rod's Avatar
Re: Dirty dingos mounts
I would go as far back as you could. This will give you a better weight distribution front to rear. Just make sure you have no interference with your headers or your intake.
Hart_Rod is offline   Reply With Quote
Old 07-25-2017, 10:01 AM   #3
cooperhw
cooperhw's Avatar
I have taken all three I have done as far back as possible. Makes more room up front too.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 07-25-2017, 07:53 PM   #4
Cheyenne350
Thank you guys for the reply s and advice...
COOPERHW; when moving all the way back did you have any type of modifying when connecting shifter? Im using a 4l60e. Also Im using f-body long tube headers what did you use?thanks
Old 07-26-2017, 05:34 PM   #5
cooperhw
cooperhw's Avatar
Wellllllllllllllllllllllllllllllllll, little bit of a clearance issue on the shifter, But, I did drop mine about 10 inches in the front and 12 in the rear. So yeah, little bit of sheet metal surgery.
I am using stock F-body exhaust manifolds.
Later,
Wayne
