Old 07-24-2017, 10:34 PM   #1
1972RedNeck
1972RedNeck's Avatar
A/C BTU's
So me and my buddies were discussing the ins and outs of '60's and early '70's A/C systems this afternoon when we came up with a question that none of us could answer and Google was of no use so I thought I would bring it before the A/C experts.
How many BTU's per hour does the average factory installed GM pickup A/C put out?
Thoughts? How does this rating compare to newer standard cab vehicles?
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 07-25-2017, 11:11 AM   #2
harpo231
harpo231's Avatar
Re: A/C BTU's
British Thermal Unit is a measurement of how much energy is required to raise the temperature of one pound of water by one degree. A lot of factors go into this calculation.
Roughly a 150 sf area takes 5000 btu's , 200 sf takes 6000 etc
Stan
67 swb BLU MULE
posted via flip-fone
harpo231 is offline   Reply With Quote
Old 07-25-2017, 11:27 AM   #3
Andy4639
Old member
Andy4639's Avatar
Question Re: A/C BTU's
From what I found on google
Most auto AC's are right around 5 tons.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 07-25-2017, 01:23 PM   #4
harpo231
harpo231's Avatar
Re: A/C BTU's
Tonnage refers to how many btu of air removed in an hour. Benchmark is about 20 btu per sf, Since vehicle is all windows may take more.
truck cab roughly 100 sf
Stan
67 swb BLU MULE
Old 07-25-2017, 09:17 PM   #5
gvw5400
gvw5400's Avatar
Re: A/C BTU's
I think I remember a "ton " of A/C is about 12,000 btu's.
Back in the day it equaled the cooling of 2000 lbs. of ice.
My truck only has 2/70 cooling with additional twin vent wing auxiliary coolers for the
over 90F. days!
All the Best, Dirk
gvw5400 is offline   Reply With Quote
