Old 07-24-2017, 11:54 PM   #1
Edahall
Rear door glass removal
What's the trick to remove the glass on the rear door of a 4 door truck / Suburban?
Also, the power window is making a grinding noise when extending or retracting like it is stripped out.
1990 ¾ ton 4x4 Chevy Suburban
-Cummins Diesel - 12 valve - factory rebuilt
-6 speed bullet proof manual transmission - NV5600
-Gear Vendors Overdrive - HX35 Holset Turbo
-NP205 iron transfer case
-3.73 gears -2" Lift
Edahall is offline   Reply With Quote
Old 07-25-2017, 12:45 PM   #2
Edahall
Re: Rear door glass removal
Here's where I'm at. Tried unbolting the window regulator and that didn't work. Then tried removing that window guide rail but it won't come out. Will the small window have to come out?
