Old 07-25-2017, 11:49 PM   #1
Robznob11
Robznob11's Avatar
Unhappy 67-72 tailgate pics needed
Ok guys, went to put the handle and latches in the new painted gate and ran into a snag! I noticed that the little angled part of the latch was opposite on one from the other! I did not see markings so im scratching my head wondering if it matters! I dont want to chip paint fighting it if it does! I would like a pic of both sides installed please! Also has anyone had to space the handle to get it to operate without dragging? Im questioning the repop gate!
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 07-26-2017, 12:16 AM   #2
rockyrivermark
Re: 67-72 tailgate pics needed
I'm not sure i follow you correctly. Here's my best guess.
Last month I installed new latches and re assembled the handle and latch rods.
So the angled part of the latch hits the bedside strike short point of the angle first. If one side is not that way then it was installed backward.
If I remember right the rods are not right or left handed and can be used on either side.
On one side the rod goes in the bottom of the latch first and on the other it goes on the top of the latch first, does that make sense?
Kind hard to explain without pics which I don't have unfortunately. I can take some tomorrow if someone doesn't follow up with some first.
Feel free to Pm
On a side note. My tailgate was original but my bedsides were repop. My tailgate was loose in the hinges with right to left lateral movement. So if I wasnt careful the tailgate would hit edge of bedside.
I used stainless steel fender washers inside the hinge cup on the bedside part to eliminate that play on each side. Worked really well
Mark
rockyrivermark is offline   Reply With Quote
Old 07-26-2017, 06:32 AM   #3
Robznob11
Robznob11's Avatar
Yes sir just looking at the latch I would asume that the taper would hit the latch reciptical first. Biut if you look at the latch it has two corners cut off and only bolts to the gate one way. The problem is that one of my latches is opposite of the other, which i find strange. The rods look the same. With that said I pulled these from an original doner gateband sent them to paint. My thought was that some where down the road someone fooled with the latch. But i looked at the latch and I dont see an easy way to take it appart and remove it. Furthermore I found and image on the net of a new replacement that is the same direction. This made me think it was a detail i took for granted and over looked! So i wanted pics of others to seebif that was the case!
LED TAILS
Old 07-26-2017, 11:28 AM   #4
Robznob11
Robznob11's Avatar
No one can snap a picture of their latches? I have one like the one pictured and on the other the taper points towards the side with the corners trimmed down!
LED TAILS
Old 07-26-2017, 12:41 PM   #5
randy500
Here is a pic
randy500 is offline   Reply With Quote
Old 07-26-2017, 01:31 PM   #6
Robznob11
Robznob11's Avatar
Those are all the same🤔 im kinda looking for pics of them actually installed on a truck! I appreciate you! My question is why do i have one opposite! And to my knowledge that would require one to cut it appart, turn it around and re weld it! My mind is blown!
LED TAILS
Old 07-26-2017, 02:14 PM   #7
randy500
I can get a pic of them installed....
Old 07-26-2017, 02:33 PM   #8
Robznob11
Robznob11's Avatar
Just out of curiosity Randy is the other side the same direction. My pass side looks just like that but when i bolt up the driver's side (they only fit one way) the taper points the opposite direction
LED TAILS
Old 07-26-2017, 02:45 PM   #9
402Bowtie
402Bowtie's Avatar
Post #3 in this link should answer your question.
402Bowtie is offline   Reply With Quote
Old 07-26-2017, 02:53 PM   #10
Robznob11
Robznob11's Avatar
Yes it does! The question is ........ WHY????? Would someone go through the trouble to reverse it???? Im baffled! Sux to caus its painted!!!! 😠😠😠
LED TAILS
Old 07-26-2017, 02:59 PM   #11
402Bowtie
402Bowtie's Avatar
You mentioned that you "went to put on the handle and latches"....are you simply installing the latch upside down? If you rotate it 180 degrees, does that solve the problem? I'm guessing there is more involved that I am not understanding.
Old 07-26-2017, 03:04 PM   #12
67ChevyRedneck
67ChevyRedneck's Avatar
Yeah, they're not left or right specific, if you turn it around it should be correct. It is possible someone took it apart and put it back together wrong... but why?
They act just like a door latch on your house, the tapered end always faces the striker. If it was the opposite way the latch would just slam on the striker and nothing would happen and your gate wouldn't close.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 07-26-2017, 03:09 PM   #13
Robznob11
Robznob11's Avatar
Well the corners are trimmed so it will clear the bodyline of the gate. I might get away with trimming a corner and flipping it over. Its a no go without a trim tho!
LED TAILS
Old 07-26-2017, 03:12 PM   #14
67ChevyRedneck
Now you've got me curious. I'll have to check mine when I get home, I could have sworn they were not L/R specific.
Jesse James
Project "On a Dime"
Old 07-26-2017, 03:21 PM   #15
Robznob11
Robznob11's Avatar
They are not, but since mine has been jacked with, it needs trimmed!
LED TAILS
Old 07-26-2017, 03:43 PM   #16
randy500
I have 2 gates off the truck, one on the truck and 4 latches, they are all the same, yours must have been assembled wrong at the factory?
Old 07-26-2017, 03:47 PM   #17
Robznob11
Robznob11's Avatar
Yup, just my luck😞 im hoping i can tape it off and trim a corner enough to fit!
LED TAILS
Old 07-26-2017, 03:55 PM   #18
rockyrivermark
Now I follow you. The angle wasn't on the latch but rather that latch plate.
Urgh. That is annoying!
Mark
My build page
http://67-72chevytrucks.com/vboard/s...d.php?t=764662
My cabinet building site
http://www.cbcabinets.com
Old 07-26-2017, 11:40 PM   #19
Robznob11
Robznob11's Avatar
Sometimes you have to improvise 🙄
LED TAILS
Old 07-27-2017, 04:18 AM   #20
rockyrivermark
Looks like a nice fit. Who makes the tailgate? Where did u get it from?
I've read that the repop gates are thin gauge and u can't sit on them. This true? What's your overall vibe on them.
Thanks. Mark.
Old 07-27-2017, 07:19 AM   #21
Robznob11
Robznob11's Avatar
Feels thinner! Im 180 lbs, i stood on mine! But definitely thinner feeling! For show they work fine
LED TAILS
