Old 07-26-2017, 01:09 AM   #1
hussler
hussler's Avatar
PLEASE HELP Trying to Install A van tilt in 68
Hi. (Working on1968 C-10) I am not having any luck finding the right answers... I'm desperate I have a show and shine this weekend and I got stuck at how do I get this van tilt column to fit in my 68 C-10
The only joint is the rag joint. Someone please help what do I need to complete this swap? Or am I SCREWED. Sorry for begging but that what it's come down to.. here's some pix of what I have going on...
hussler is offline   Reply With Quote
Old 07-26-2017, 01:12 AM   #2
hussler
hussler's Avatar
Old 07-26-2017, 01:44 AM   #3
randy500
Re: PLEASE HELP Trying to Install A van tilt in 68
69 to 72 have an intermediate shaft which connects between the column and the rAg joint, you need one of those and you will need to collapse it about 1.5 inches to accommodate the extra shaft length of the van column. Do a search here on the form for the details on how to collapse the shaft, its its clean and not rusty the easiest way is to bang the ag joint end on a concrete floor, quick and easy that way.
randy500 is offline   Reply With Quote
Old 07-26-2017, 01:59 AM   #4
hussler
hussler's Avatar
Ahhh That makes sense...Now to find a intermittent shaft. Thanks randy500
Old 07-26-2017, 05:53 AM   #5
Are those your columns in the pictures? Looks like you have a non-tilt 69-72 column with lower shaft right there. Just swap that over.
Old 07-26-2017, 09:32 AM   #6
LockDoc
The Older Generation
LockDoc's Avatar
I think that is the '67-'68 one piece shaft Tim.
LockDoc
Leon
Old 07-27-2017, 08:15 AM   #7
Ok, sorry for the bad info. Thought that was a coupler. That area is all dark on my computer. Must have glanced over the second picture. I have one if needed. Won't help for this weekend. I hope you find one before the show.
Old 07-27-2017, 08:04 PM   #8
hussler
hussler's Avatar
Ok.. so i picked up a intermediate shaft yesterday and cleaned it all up also drilled out the plastic stoppers needed a little heat and collapsed it 1-1/2" hopefully will install tonight. Whats the best way to install the column? should i put it together first out side the truck? wheels are turned straight right now how can i make sure i line up the spline on the steering wheel end so my steering wheel is centered properly? Or does it even matter on our trucks?
Old 07-27-2017, 08:51 PM   #9
randy500
The rag joint intermediate shaft and the column each only install one way.
Old 07-27-2017, 08:53 PM   #10
randy500
It is extremely baffling to me why people feel the need to drill out those plastic injection points...does anybody really feel those would take any measureable amount of force to shear?
Old 07-27-2017, 09:21 PM   #11
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Have you tried to collapse one by hand? With a hammer? They just don't pop and slide with minimal force. Maybe they did when they were new or 2-5 years after that. Then throw into the equation rust/corrosion and it just became nearly solid.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 07-27-2017, 10:10 PM   #12
randy500
I've done dozens by hand, bang it onto the concrete floor, did one recently.
The plastic isn't holding anything in place, it's the rust that holds them. In good shape the plastic shears with the first solid hit and I don't hit it very hard.
Old 07-28-2017, 12:21 AM   #13
Dieselwrencher
Then you're very lucky you don't live in the rust belt.
Ryan
Old 07-28-2017, 12:33 AM   #14
hussler
hussler's Avatar
Hmmm I tried several times banging it against concret floor also took a 5lbs sledge hammer to it wouldn't budge until i drilled it plus Kroll penetrating spray and heat then it moved. Couldn't get to it tonight to finish the swap but tomorrow after work, then head out to the show & shine Sat morning, fingers crossed all goes well.
Old 07-28-2017, 09:18 AM   #15
LockDoc
LockDoc's Avatar
I've never got one to move on it's own either. It's heat, penetrating oil, and a big vise for me...... I have two to do next week.
LockDoc
Leon
Old 07-28-2017, 10:31 AM   #16
Dieselwrencher
LockDoc
Same here. I guess we need to get some from WA to save some stress and time. A whole truck would be sweet. Maybe someday.
Ryan
Old 07-28-2017, 10:37 AM   #17
67 chevelle
67 chevelle's Avatar
had to put heat to mine to get it moving , it was difficult , doing it installed , with a large prybar and heat
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
