Big Block
AC options. Looking for the best operation AC unit.
Looking at different options. Have factory AC that hasn't worked for over 20 years. The system is intact. I'm not sure if it's worth the time and money to try to get the old system up and running. We're having one of those summers. Super high humility and temps in the high 90's every day. Don't want to drive anything that doesn't have AC. I was talking to a co-worker who said beware of the gen 4 Vintage Air unit. He said they're having trouble with electronic solenoid. Has anyone experienced that with a gen 4 Vintage Air unit? That's why I have been looking at other options. The stock cables and factory style site glass would seem more reliable than electronics. But like I said this is all new to me.*The Old Air Hurricane unit uses factory AC controls and uses the original ductwork, also has the site glass. Any help is appreciated. Just weighing my options. I don't want to waste time and money on a AC unit that's not going to work in high humility and temps. Thanks
Re: AC options. Looking for the best operation AC unit.
I used the old air kit. It is the worst thing I have ever done to my suburban.
If you turn the heat on after the ac has been on the entire inside of the suburban fills with condensation. I have talked with tech support and never got any further than its not draining.. I have confirmed the drain tube is clear and had good slope to drain. The other thing you may not realize is with factory heat and ac you can run down the road on a cool morning with the heat lever over at hot and the cab gets warn without fan speed. all the new under dash units eliminate the fresh air intake and require fan speed to heat/cool cab. I have well over $1500 Canadian into my ac if it costed $2500 for factory I wish I would have fixed it.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
I am very happy with my VA unit. Straight forward install and cold air. No problems thus far.
(Two Arizona summers) |
If it was me, I would fix what you have and use R12.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
#5 | |
Old member
![]() Quote:
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Big Block
Thanks guys for the advice. I think I'll replace some of the obvious parts that need to be changed. Dryer, compressor and POA for sure. I already have a compressor and condenser coil that a friend didn't end up using in his project. So I'm going to flush out the evaporator coil and the rest of the lines. Pull a vacuum and see what happens. If anyone can think of anything else don't hesitate to chime in. This is going to be my first attempt at AC work.
#7 | |
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 Last edited by hdff; 07-28-2017 at 01:14 PM. |
#8 | |
Big Block
Did you upgrade the POA valve to 134 or did you stay with R12? |
I stayed with r12. faa benny can help you out if you wanna change the poa to 134
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
Using Vintage Air in my 72. Here's a recent screen shot of my phone, which tells the story. The temp at the center vent was 42 degrees and I was cool.
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
