Old 07-26-2017, 03:38 PM   #1
Haru
Haru's Avatar
Side mirror
Sport side mirrors, is the hole really 11/32 ? Seems like a large hole to drill? I've read all the posts and seen the alignment / specs but concerned that's too big a hole. Am I reading that wrong? Thanks in advance
-71 C10 long bed, 402
-91 Camaro Z28, B2L 350
-96 Tahoe 2 door 2wd
-15 Tahoe LT
-16 Lexus RC 350 F sport
Haru is offline   Reply With Quote
Old 07-26-2017, 03:49 PM   #2
randy500
Re: Side mirror
It is a large hole, I use a 3/8 spot weld cutter to cut the hole...
randy500 is offline   Reply With Quote
Old 07-26-2017, 05:43 PM   #3
Haru
Haru's Avatar
Re: Side mirror
-15 Tahoe LT
Old 07-26-2017, 06:53 PM   #4
72.4me
Re: Side mirror
When I installed mine I drilled a smaller hole also, Im guessing the reason is because it screws to the backing plate not the body and with a larger hole you would have room for adjustment..but still I went with a smaller hole.
72.4me is offline   Reply With Quote
Old 07-26-2017, 07:00 PM   #5
Haru
Haru's Avatar
Re: Side mirror
Thabks! What size did you actually drill?
-15 Tahoe LT
Old 07-26-2017, 07:09 PM   #6
72.4me
Re: Side mirror
Its been a few years so sorry I cant remember, as long as the screw slides through you should be fine, FIY once I drilled the holes I smeared some liquid steel on the backing plate, also you will need another set of hands to install.
Old 07-26-2017, 07:19 PM   #7
Haru
Haru's Avatar
Re: Side mirror
Sweet, thank you!
-15 Tahoe LT
Old 07-27-2017, 01:46 AM   #8
Haru
Haru's Avatar
Re: Side mirror
Bye farm truck mirrors
-15 Tahoe LT
