07-26-2017, 05:59 PM | #1 |
20' Daredevil (Ret)
Warmer air at A/C ducts
Got my A/C working again for the first time in many years. Converted to R134a, new parts installed by a local mechanic (don't shoot me). Got a problem we can't figure out, though. I have searched a ton of threads and can't find a solution.
It's blowing lots of air but it's quite a bit warmer at the vents than at the bottom of the HVAC airbox. In my driveway around noon, ambient temp nearly 90 degrees. Had 33 degrees at the bottom of the airbox (great, right?) but 62 at all three A/C vents. Ran it for a good long time, mostly shaded by a tree, no difference. Ducting is new, undamaged, and properly connected. I'm at the end of my rope and need a miracle. Thanks for any help.
07-26-2017, 06:41 PM | #2 |
Re: Warmer air at A/C ducts
Hmmm, I'm going to be watching this thread to gain knowledge. It sounds like warm air is mixing with cold before it goes through the ducts, but I don't know the air flow of one of these things yet. What parts are new?
07-26-2017, 06:53 PM | #3 |
dmjlambert beat me to it, check the blend door, sounds like it's mixing in heated air. Also, check the heater control valve on the pass. fender. It should be off when A/C is on.
07-26-2017, 06:56 PM | #4 |
20' Daredevil (Ret)
Compressor, condenser, hoses & muffler, POA valve, expansion valve, receiver/drier, and ducts & outlet vents inside the cab.
07-26-2017, 07:07 PM | #5 | |
20' Daredevil (Ret)
The heater control valve is new, and for extra insurance there is a ball valve in the heater hose going to the control valve. There is no heat coming out of the heater core.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay Last edited by Stocker; 07-26-2017 at 08:01 PM. |
07-26-2017, 07:29 PM | #6 | |
Old member
Are the vacuum canisters working correctly? It sounds to me the cowl vent is open and warm air is coming inside the cab.
07-26-2017, 07:48 PM | #7 |
20' Daredevil (Ret)
Hi Andy, glad you popped in.
Are you talking about air blowing in through a cowl vent while driving? I'm doing my testing while parked in the driveway & carport so that wouldn't be an issue. If not, give me a bit more specific info so I'll know what to look for. Thanks! What I called the HVAC airbox (wrong term, maybe?) is inside the cab, under the glove box. Heated or cooled air is routed from there through the ducts to the outlet vents.
07-26-2017, 07:57 PM | #8 | |
20' Daredevil (Ret)
07-26-2017, 08:36 PM | #9 | |
Old member
The cable goes outside to the eveperator box and is mounted to a metal rod which goes down inside the box. When you want AC it closes off the path to the heater and forces all the air flow across the eveperator coils. You have to set it to work correctly are as you found out it will let air bypass and come into the cab with no cooling effect. Here is the flapper you need to close and open. You need to adjust all the cables to operate correcly to get the max out of both AC and heat.
07-26-2017, 09:14 PM | #10 | |
20' Daredevil (Ret)
If I slide the control lever to hot, I get very hot air from the ducts. With AC on, I had 33 degrees in the airbox under the dash, leading me to believe the system is working. But 60+ degrees at the vents. Is there some other secret passage where heat can enter the duct system? This is where I am stuck.
07-26-2017, 10:19 PM | #11 | |
With 33°F at the evaporator, the refrigeration system is working well enough to look at other issues for now. You have airflow at the registers. This can only happen if the blower fan pushes air to the registers. It can't really come from anywhere else. However, the air at the registers is much warmer than at the evaporator. So there are only two possibilities I can think of (hold the jokes, please):
You effectively ruled out #1 by installing the ball valve in the heater hose, so it more or less has to be #2. It looks like the door Andy pointed out opens to bypass the evaporator when the temperature control lever is moved to the HOT position. So that's at least somewhere to start. I wouldn't want to open the evaporator box, but removing the blower fan may give you a peek at the door from the front, and let you verify that it is closing fully. If not, hopefully there is room for adjustment at one end of the cable. It may also be possible that the installers left out a gasket, used the wrong gasket, damaged a gasket, or otherwise made an error that allows air to bypass the evaporator even when the door is fully closed. Best-o'-luck. It's awful close now. Has to be. And since I can't find the AMC logo (what kind of two-bit sleazy dive is this, anyway?) to counter your bowtie, have a wave.
'85 Jeep J20 OMFT (old man fishing truck), 66K original miles - all the good Chevy/GMC stuff around here was taken! |
07-26-2017, 10:44 PM | #12 |
check the temperature of the heater core or heater hoses.With the A/C on the valve should close so no hot coolant goes into the heater core.
07-26-2017, 10:47 PM | #13 |
20' Daredevil (Ret)
Thanks for the suggestions, Aaron. Lemme answer the easy one first. The techs only worked under the hood, removing & replacing the parts I mentioned in post 4 above. I did the ducts & outlets in the cab. No other major parts were touched, no gaskets were disturbed.... they are all original 46-year-old parts. Which is not to say chunks of those old gaskets might not have disappeared over the years....
I haven't yet wrapped my head around warm air bypassing the evap core, given that I have 33-degree air blasting into the distribution box (or whatever it's called) under the glove box. Isn't that where the cold air is coming from -- the box that the evap core sits in? At any rate, whether I understand it or not doesn't matter. What matters is that warm air is somehow getting into the system. I'll see if I can pull the fan in order to eyeball the blend door.
07-26-2017, 10:51 PM | #14 |
20' Daredevil (Ret)
Yep! I have a new heater control valve and I added a ball valve in the heater hose going to it. Heater core is cool to the touch and the hoses have just minimal warmth from being next to a running engine.
07-26-2017, 10:55 PM | #15 | |||
Anyway, I'm really glad to hear that the air is cold at least somewhere in the system, if not everywhere.
07-26-2017, 11:04 PM | #16 | |
You can't rely on the air goes from hot to cold by operating the lever, disconnect the cable and see if you can close the door further, it is probably open a little bit allowing the air from the fan to bypass the evaporator, even more likely is that it's open a little bit because debris is keeping it from closing all the way. Where exactly is this 33 degree air at? |
07-26-2017, 11:06 PM | #17 |
You can get to that door from the inside of the cab by removing the glovebox and duct that pushes the air to the a/c vents, its a job though and have to take out the inner fender I think to get to some of the nuts.
07-26-2017, 11:58 PM | #18 |
20' Daredevil (Ret)
Thanks Randy, the next thing I will do is check the cable operation of the blend door. Easy stuff first! Hopefully it's that simple..... we will see.
I don't know the correct name for all these parts. Let's try this -- pretty much centered beneath the glove box is a large composite chamber that attaches to the firewall. On the bottom of that chamber is a small (~1 1/2" x 1 1/2") metal trap door. That is where I inserted the thermometer probe.
07-27-2017, 12:13 AM | #19 | |
The air past that goes to the a/c diverted valve, visible below he dash and if original is an army green color, the valve is usually broke inside that, it diverts the airflow to either the a/c vents or onto the heater vent which has another valve to divert the air to the defrost vents. If the a/c diverted valve is broke the air can be directed to both locations which when spread across all e vents is not much airflow to any of them. Keep in mind the truck is 45 years old and pulls air from the unfiltered cowl, the outside box and the evaporator are probably full of debris. I think you could remove the outside evaporator cover on the engine side to clean that out and then move the evaporator to the side to clean the other side. I think that would work without a recharge, haven't tried it though, |
07-27-2017, 12:57 AM | #20 | |
https://youtu.be/PW8T-tXf2wE?t=5m39s I really hope you don't have to remove and/or dismantle that assembly. It looks like a real endeavor. edit: Found some more good info from F.A.A.benny in these threads: http://67-72chevytrucks.com/vboard/s...d.php?t=742484 http://67-72chevytrucks.com/vboard/s...d.php?t=742694
07-27-2017, 01:04 AM | #21 |
20' Daredevil (Ret)
Randy500 and DarkMonohue: Great information to have, thanks very much! Sounds more & more like I'll be digging into this more than I ever wanted to. I'll do as much as I can and if it needs more attention than I can handle.... it's gonna be in the shop again to replace the noisy (new) compressor.
It may well have some diverter valve issues. A/C sends virtually all the air to the correct vents, but heater and defroster settings allow some air to exit the A/C vents too.
07-27-2017, 06:18 AM | #22 |
Old member
I will say this again. The flapper in the cowl works off the vacuum canister. If that flapper under the cowl is opening instead of closing then you are letting hot air inside the cab. If it's not closing all the way you are letting hot air inside the cab.
The vacuum canister that operate the AC vents are different from each other they are not the same. You have to have them in the right spot are they work backwards of what they are suppose to do. On my 71 I sealed the cowl vent off it is non functional now to keep hot air out of the cab.
07-27-2017, 09:09 AM | #23 | |
20' Daredevil (Ret)
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay Last edited by Stocker; 07-27-2017 at 09:15 AM. |
07-27-2017, 10:41 AM | #24 |
Old member
The cowl vent should have anything to do with the kick panel vent. It has it's own vacuum canister for operation.
On my 71 the cowl is sealed off completely non functional. The inside kick panel I put back to manual open and shut. I leave it open all the time and this cools the truck down very nice. It's like the newer vehicles recirc. If the cowl vent isn't sealing good it draws hot air into the system which that's what it's for.
07-27-2017, 12:03 PM | #25 | |
20' Daredevil (Ret)
Question -- will the cowl vent draw hot air in only if the truck is moving, or does it also draw hot air in when sitting still?
