![]() ![]() Join Date: Feb 2009
Why for I cannot remove the rear main brake line?
Trying to remove the rear main line from the "rear brakes distribution hose", for lack of better term.
For what it's worth, this truck isn't rusty. Everything has pulled off "easily". But this tube nut is on TIGHT. Am I missing something or do I just go at it?. I'm using a 7/16 Snap-on line tool and oil, and I'm about ready to put a pipe on it, which probably nuts-up the nut and I'd rather not. Come to think of it, maybe I'll hit it with some heat. EDIT: Sorry, you put heat on it ![]() Thank you.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 07-27-2017 at 12:14 AM. |
Post Whore
![]() Join Date: Feb 2016
Re: Why for I cannot remove the rear main brake line?
Brake fittings can rust on the inside from moisture in the fluid. I would go the propane torch route, but do to the dangers involved I generally would not recommend it for someone else, but since your going down that road. Please take care not to burn the hose (Or the truck!) Get some of that canned air (for cleaning computers) so after you heat the fitting on the hose side you can spray the fitting on the tube to cool it fast. If you spray the canned air inverted it comes out liquid and very cold. Have your wrenches ready and go for it. If your replacing the hose you can put a pair of vice grips on that fitting to keep it from trying to spin in the bracket.
Good luck.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#3 | |
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
Old member
They are a pain in the you know what to get off. I took mine off with the bed on it was tough but I got it finally.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#5 | |
Took a little heat from small propane torch. Came right off, just don't over do it with the heat. You want to beat the part that the bolt goes into. Expand that with heat. Mark
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com |
I still don't own a torch. Course there's the suspension to pull yet, but I suspect if heat is needed the heat gun will do. Lucky my first build isn't rusted up, "I've made"
![]() Join Date: Jul 2015
Sounds like you have got it done. Heat almost always works taking old rusty nuts and bolt off. If heat alone does not do it, Try hitting it with a garden hose for the cooling a few cycles.
After that Heat/Cool cycle thing does not work after 3 or more tries I break out the IMPACT. Whether its the Hammer Socket, Air Impact, or Hammer and Wrench. I have yet to lose, the real rusturds get cut off wheel. |
Vise Grips?
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
#9 | |
It was just by chance the connections before the OP were easy. Since then I put heat on both connections on the rear distribution hose, one rear brake tube, and all of the front brake tubes. Post #2 wasn't kidding, must be moisture in the lines.
Bet my 72 would be a real blast. The lines are crusty, which bodes well with the state of the cab. The tubes on the project will look like new once the paint is removed. Less the rear lines anyway, because someone stripped the nuts for me. Quote:
Sure, if the nuts are already gone. They work great for pulling the clip off the brake hose brackets.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 07-28-2017 at 01:30 AM. |
professional advice;
cut and replace.. brake fluid is hygroscopic, no telling what lies inside the walls of them there tubes and all.. wasted effort saving non serviceable parts.. non-professional advice; if must keep, soak in mopar, kroil, blaster, etc. and apply steady force with sharp flare nut tools.. rotate backup/working wrench to comfortable squeeze and hang on.. the gentle stretching will work the penetrant into threads and they'll usually give eventually.. hammering, yanking, cursing, etc.. all more wasted effort.. good luck! |
#11 | |
ugh.......when I take my truck over to the shop to get the A arms replaced I might have the guy replace all the brake lines also.
I wish I was nearby you brother, I'd love to come over and help. I've been on a diet and been working out, I'm much more able to fit under trucks now and more flexible to do it faster. Try a soldering iron....you might could heat it up enough that way to break that rust hold. It would take longer but be less annoying than a heat gun. |
#13 |
Post Whore
The tube nuts are OK with heat, but you want the inner piece of the stuck components to shrink with cold and the outer piece to expand with heat. Hopefully then you can loosen the pieces.
#14 |
Post Whore
Last ditch use only. This is the most likely result.
#15 | |
my professional background is heavy junk and I supervise several automotive trades for a few years now so there's that.. rolling up close to 30 years in this industry, boy I feel old saying that..
we buy 99% OEM prebent assemblies but then I don't see much 60's and 70's on-highway vehicles.. the vendor you mentioned looks like a great option for OE-like steel assemblies discontinued by OEM.. my first and foremost preference will always be the steel tubing bent safely through the chassis where it needs to go.. making the longest continuous runs as possible with least number of connections possible.. if prebent assemblies aren't available, buy some decent tools and learn how to do it yourself.. small diameter stuff like this is simple and even if you fudge your bend points it may still get where it needs to go.. 3/4 .120 wall 304SS is a whole 'nother animal not for the novice.. I have ordered the alloy Fedhill type stuff for some projects where bending steel tubing was labor cost prohibitive due to complexity on specialized equipment and the lines were enclosed in frame channels.. stuff was pretty cool and easy to work with, my guys liked it but doesn't lie straight very well so it wouldn't look as neat as OE without a lot of tweaking.. that stuff is also vulnerable to external hazards so I'm not sold on it for for all applications and certainly not for trucks that have any intentions on working for a living.. hobby car or weekend putter that not really concerned about what it looks like underneath, maybe a viable solution since it is DOT.. I will also add that when you encounter line issues of this nature, the other brake components are likely affected to some degree.. tubing, junctions, hoses and cylinders are not that expensive to replace all together especially considering the critical nature of that system in the vehicle.. cut your budget elsewhere and spend appropriately on the safety systems.. brake fluid is hygroscopic and most brake components are steel exposed to weather on the outside.. corrosion is the nature of the beast and hydraulic brake systems seem to be one of the most neglected vehicle systems I have encountered.. proper maintenance and service and your factory brake system can last your lifetime.. good luck! |
#16 | |
Gold star response, I really appreciate it. I prefer get through this restoration without unbent & non-flared tubing. 99% of these parts are news to me as is. I'm leaning toward Inline Tube pending references, but there are other options. By the way, great timing. Removing paint & polish was just around the corner.
