Old 07-27-2017, 08:55 AM   #1
blown32
C10 doors to Blazer doors
I'm sure this has been done. Has anyone cut down 69-72 C10 doors and made them into Blazer doors. They look the same other then doing away with the top portion of the window frame. Any problems in doing this?
blown32 is offline   Reply With Quote
Old 07-27-2017, 09:07 AM   #2
1rippen6
Re: C10 doors to Blazer doors
That's how the factory did it, if I'm not mistaken the assembly manual you can buy shows the process.
1rippen6 is offline   Reply With Quote
Old 07-27-2017, 09:14 AM   #3
blown32
Thank you, this information is helpful!
Old 07-27-2017, 09:34 AM   #4
hemi43
hemi43's Avatar
I seem to recall Blazer doors have reinforcement pieces built into them that the truck doors don't have. Someone might confirm this.
hemi43 is offline   Reply With Quote
Old 07-27-2017, 09:43 AM   #5
D.PASSMORE
One of the First
D.PASSMORE's Avatar
You can use truck doors, but suburban doors will work too.
Updated: Here you go -
http://67-72chevytrucks.com/vboard/s...d.php?t=273729
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 07-27-2017, 10:36 AM   #6
1rippen6
You are correct they have a reinforcement plate spot welded in at the latch area. Remove them from your current doors before you scrap them I don't know how many sets of those I have sold. There is also a stainless steel plate that is screwed to the doors that the truck door will not have.
Old 07-27-2017, 11:06 AM   #7
6768chevylover
6768chevylover's Avatar
I'm actually going to do this myself. It is in the assembly manual. there are three cuts to make.. I'm going to a bone yard to get doors this weekend as long as they are in good shape...
6768chevylover is offline   Reply With Quote
Old 07-27-2017, 12:13 PM   #8
lolife99
67-72 parts collector,…
lolife99's Avatar
Here you go - http://67-72chevytrucks.com/vboard/s...d.php?t=273729
Your link doesn't work for me.
Keith
Convert to disc brakes.
Old 07-27-2017, 04:25 PM   #9
blown32
The previous owner trashed the original Blazer doors and put truck doors on so I guess I'm out of luck. I will have to try to fabricate some new parts or look for donor Plates.
Thank you everyone for your replies!
Old 07-27-2017, 08:22 PM   #10
Blazer690
Blazer690's Avatar
I have made door plates out of bad doors. cut out the area around the latch and roset weld it to your door
Blazer690 is offline   Reply With Quote
Old 07-27-2017, 09:47 PM   #11
1rippen6
Good idea
Old 07-27-2017, 09:48 PM   #12
1rippen6
I have a DS but it needs some TLC
