07-27-2017, 11:55 AM | #1 |
I think the AC clutch is smoked, better to get a new compressor?
Here is a video of the AC turned on:
https://www.youtube.com/watch?v=1lbA9l604pc its not cooling anymore and it looks like the clutch has some loose parts: https://www.youtube.com/watch?v=F9p0CbvYAgY I assume at this point its better to replace the whole compressor than mess around with a clutch swap. Do I do another A6 or go for a newer unit like a Sanden?? Thanks Derek.- |
07-27-2017, 02:27 PM | #2 |
Moderator
Re: I think the AC clutch is smoked, better to get a new compressor?
Get an a10 replacement. Bolts to existing oem brackets
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
07-27-2017, 02:33 PM | #3 |
70+ ( Old Skool Club )
Rock Auto has rebuilt clutches, as i couldn't find a new one anywhere. I just put one on my truck and had the a/C topped up ( 134) and its working great and really cooling. As Leddzepp said new compressor would be best but that depends on your budget.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
07-27-2017, 03:18 PM | #4 |
New compressor means a recharge, I would just change the clutch.
07-27-2017, 03:23 PM | #5 |
You can replace the clutch easily without discharging the system. You need special tools though. It is not like the Sandon in the video.
07-27-2017, 03:31 PM | #6 |
Who Changed This?
You should be able to rent the tools for removing and replacing the clutch. As has been noted, you don't have to discharge the system to do it. It's what I would do, especially if it was blowing cold before this.
