07-27-2017, 12:12 PM | #1 |
Adding factory AC to my non-AC 1970 truck
I scored a fairly complete working system (minus condensor, compressor brackets, hoses, and controls). But boxes, cables, evaporator, heater core, ducts, even a good AC glovebox.
I can get the parts missing locally unless someone has some they want to part with. Bonus is my truck already has an AC dash and I can do all the work myself. Any gurus that have done this have any advice? I figured ill pressurize the EVAP core and check for leaks and replace the heater core just to prevent needing to later, along with a new receiver drier. How do I need to modify my firewall? Are there upgrades to the POA valve or oriface tube that I should do to bring it up to modern technology? I have R-134 at my disposal but freeze 12 I can get too (and have gauges for both). Anything else?
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
07-27-2017, 01:17 PM | #2 |
Re: Adding factory AC to my non-AC 1970 truck
I put AC on my truck a few years ago. Scroll down to post #8 in:
http://67-72chevytrucks.com/vboard/s...d.php?t=478564 for details. The link in that older thread to adjust your POA broke since I posted it. Sorry about that. I'm sure the parts prices I quoted are no longer any good. Everything has gone up since then. Except my salary.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
07-27-2017, 01:29 PM | #3 | |
07-27-2017, 01:56 PM | #4 |
The flapper is in the cowl, in front of the windshield on the passenger side.
In a non-AC cab there is a dimple in the sheet metal that needs to be drilled out. I bought one of those super long drill bits as the dimple is pointed out towards the engine. I drilled the hole to factory specs from the assembly manual. Obviously the glove box is out to perform the task. I believe the hole is all you need to "add". Then it hooks up to vacuum with a T in the vacuum running other AC components. The flapper is part of the outside air/no outside air control system.
07-27-2017, 02:03 PM | #5 |
The shape and size of the openings in the firewall are different behind the a/c outside box (larger) so the firewall can be cut to a/c size. The holes for the boxes are mostly different locations, I think if you mount the outside box first you can locate the remainder inside and outside holes from the outside box.
The assembly manual has hole locations and sizes for that flapper door and the wiring/vacuume hole, maybe some more info too. A/c wiring is just an add on to regular harness. |
07-27-2017, 02:06 PM | #6 |
Is there a PDF version floating around yet?
07-27-2017, 04:30 PM | #7 |
If going with 134a you should recalibrate the poa valve
07-27-2017, 04:52 PM | #8 |
I totally understand how it works now. That may be something I didn't get with the kit.
07-27-2017, 04:56 PM | #9 |
Here is what i'm getting.
07-27-2017, 06:13 PM | #10 |
Be sure to check that distribution duct that bolts directly to the heater box. Often the blend door is broken. That duct is over $100 new
07-27-2017, 06:55 PM | #11 |
Will do. What does it look like i am missing?
07-28-2017, 05:28 AM | #12 |
laying low
Difference in firewall holes. a/c and non a/c.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
07-28-2017, 12:20 PM | #13 |
That is great information.
What benefits (and how) can I convert over to a later style oriface tube and get rid of the POA and the associated stuff to make it more reliable? Is it worth it?
07-28-2017, 12:36 PM | #14 | |
07-28-2017, 12:48 PM | #15 | |
Regarding the POA. It has nothing to do with reliability. It is just a different system. If you have a POA system, I'd use it. The factory ACs on my two Chevelles have been used reliably since 1971 and 1972. The '71 still has the factory receiver/dryer. The 72 I did some service on in 1989 at which time I opened the system to replace something - I don't even remember what any more - and replaced that receiver/dryer at that time. ANY system like this vintage, when you open it to the atmosphere, should get a new receiver dryer. The truck I converted is using a factory compressor off of a 1971 Monte Carlo. That system has been working since 2011. It has a slight leak. I replaced every o-ring in the system but didn't touch the schrader valve. Guess where it leaks?
07-28-2017, 01:30 PM | #16 | |
