Old 07-27-2017, 02:47 PM   #1
LVPhotos
LVPhotos's Avatar
Vintage Air install for 60-63 cabs
I was asked to show my Vintage air install on my 1962. I will start with a few install instruction pages. I have got to the bracket so far. I did find C10 Builder mag Summer 2016 install on 62 gmc. The bracket i ordered wont work because heads lack a hole but the Vintage one works.
The new mounting bracket does not use Existing holes in the fire wall so you have to drill (2) 9/32" holes with supplied template. Bench work installing various hoses and bracket. 1" hole in firewall for drain hose. New cover plates, square, upper fire wall if you had delux heat, passenger fresh air.
Has electric hot water shut off for max ac. The condensor and drier can be installed by removing "stock" radiator. The C10 mag had to remove grill becausr trans cooler.
Under dash ducts and new glove box provided. Nice metal switch panel fits stock dash.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
