'66 C10 Trailing Arm Swap onto '89 R30/C30?
Our shop just traded for an '89 R30 crew cab and will be picking it up soon. We're wanting to convert it to C10 suspension, and was wondering if the trailing arm suspension from a '66 C10 would work since we already have the crossmember and trailing arms. I would be relocating the shock mounts and using a full width panhard bar along with air bags, so I'm mostly wondering if the crossmember will fit in the frame.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
#2 | |
Re: '66 C10 Trailing Arm Swap onto '89 R30/C30?
yep x2 1ton frames are about 2" taller in the firewall to axle hump up in the rear main frame area .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
![]() Join Date: Jun 2016
Why use skimpy 1/2 ton parts on your 1-ton truck?
IMHO, this is a much more appropriate solution - http://67-72chevytrucks.com/vboard/s...d.php?t=669016
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find 87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4 |
#5 | |
Yeah, will be lighter duty use, more of a mild Pro-Touring setup to improve handling and stability.
John you're welcome to look at mine at the next club event or if you are up in my neck of the woods one day to see what all is involved. I have the porterbuilt kit, which I know will be different than adapting stock components. A stock 67-72 crossmember wont fit but I'm sure with your skills you could make it work no problem. If you wanted to save time you could always call up CPP and order their crossmember only for about $150 I believe. Last time I looked at porters website they no longer listed the trailing arm option for squares any longer. You could also order one of their "modular" crossmembers and build your own frame brackets which is what they wound up giving me to get mine to work and then I still had to modify it some.
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded ![]() '03 burb. Family cruiser http://upstategmtrucks.com/ |
Addicted to Rust
![]() Join Date: Dec 2009
John consider using an 88-98 rear end. They are a tick wider than a square rear end and are way easier find good ratios in. Mine is a 3.42. Jay
Current trucks: (48 GMC100 320 inliner) Gone (48 Suburban in pieces) Sold 87 GMC CCSB 5.3 4l60E Daily Driver ECTA National record holder XO/PP We never really grow up, we just learn how to act in public. |
I used a 71/72 axle on mine, that way I didn't have to worry about welding the mounts on an I got 3.73 gears at the same time...
#10 | |
We'll be using a F-body T56 so a shorter gear might be more appropriate since 6th gear is .50:1 ratio. Maybe 4:10 or 4.56 depending on the tire size we end up with.
