Old 07-29-2017, 10:42 AM   #1
edc
Transmission / rear end set up
Hey guys - sorry for what is most likely a duplicate of a duplicate of a duplicate post. I've been searching around on here, but there are SO MANY posts!!! I love reading through the posts, but not when I'm on a mission for something specific.... LOL
'65 LWB
283 V8 :: PS / PB / elect ign
350 auto with towing shift kit :: I think it's a TH?
3:73 rear end :: guessing
Engine and trans rebuilt ~ 3 years / 3,000 miles ago
Last owner used it on the farm sparingly for his horses. I don't tow anything, but I bought the truck to USE it. I haul lumber and furniture and mulch and stuff with it. She ain't a show truck and I have no plans of hot-rodding it.
Problem is I can't drive it on the highway for long at all. It SCREAMS at 70 mph. This is what I need to remedy. (That and I get maybe 8-9 MPG.)
What's my best option?
- Change the rear end? (to what?)
- Go to a 700R4?
- Do both?
Thanks in advance for the input - you guys are the best!
1965 C-10 LWB SBW 283/350 auto
aka The Beater
edc is offline   Reply With Quote
Old 07-29-2017, 10:56 AM   #2
LVPhotos
LVPhotos's Avatar
Re: Transmission / rear end set up
Overdrive or slow down. 3:08 will still be 3000 at 70. How tall a tire because a simple tire change can help. A 28"+ tire works well with 3.73 gears
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 07-29-2017, 06:33 PM   #3
rvrfoot
'65 LWB
- Go to a 700R4?
- Do both?
I am having the same problem.The rear end shop told me the 308 or 325 will be good.
rvrfoot is offline   Reply With Quote
Old 07-29-2017, 06:36 PM   #4
rvrfoot
It looks like the sweet spot is 26 to 30 inch tires with 373.The speed limit is 65.
Old 07-29-2017, 07:27 PM   #5
LVPhotos
LVPhotos's Avatar
I run a 295/45/18 (28.42") about stock height, and 3.73 gears but the od drops 800-900 rpms @75. So in 1:1 4th gear 2900 to 3000 rpm
Old 07-29-2017, 07:33 PM   #6
rvrfoot
So in a 350 we need overdrive Or a 308 rear end gear.
Old 07-29-2017, 07:36 PM   #7
LVPhotos
LVPhotos's Avatar
Or a taller tire
Old 09-03-2017, 12:03 PM   #8
edc
Hey guys - thanks for the comments.....
Average highway speed limit out here is 65. <-- That's my goal. My days of street racing are long behind me.
Taller tires are out. These are as big as I want to go. I'm running 235/75R15s with a total height of about 27.5-28".
If the truck *does* have the 3.73 rear end, I guess I really should be okay. If it has the optional 3.07 or 4.11, I'm borderline. Reckon I just need to pull the cover off and count teeth to be sure.
I've got a guy who can do a rebuilt 700R4 and gear swap (he recommended 3.08) for about $2500.
Thanks again!
aka The Beater
Old 09-03-2017, 02:32 PM   #9
Chevy Fleetside
Chevy Fleetside's Avatar
I have a 700R4 with 3.08 rear in my truck running 275/60/15 tires which I believe is about 28" tall. It tach's about 2200 rpm at 75MPH. I do have a BB, I really have not done a MPG average but from what I did it was at low end 12 MPG. Running a Q-Jet carb.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 09-03-2017, 02:35 PM   #10
YOLO
Custom Truck Lover!
YOLO's Avatar
I just fixed this exact issue. I have a stock rear end with 373 gears. The transmission was a T350, 27.5 inch tires and unknown cam. I could not go faster than 60-65 without my tachometer pinging out of the gauge. I ordered a 700r4, 2000 stall (daily driver) from Animal Performance in FL. I can now drive 80mph at a very low RPM and have a lot of power to play with. My truck is not a performer and somewhat slow off the line. If I ordered again my stall would have been 2200 to 2500 but I am very happy with it.
Squarebody guy
YOLO is offline   Reply With Quote
Old 09-03-2017, 06:18 PM   #11
63burban
Chevy addict
Stock 700r4 and 3:42 gears if that's an option for you, great all around set up. That is actually Chevy's Z71 set up and works great. I have this combo in three vehicles. My 56 Chevy gets 22mpg with a 305 and Edelbrock carb.
63burban is offline   Reply With Quote
Old 09-03-2017, 06:23 PM   #12
Brad54
Brad54's Avatar
I've got a 4spd manual trans in mine, with 3.42 gears in the Dana 44; OD is .73:1, and the rest of the gears are the same as the TH350.
235/75/15 tires.
Honks down the highway perfectly at any speed you'd like, gets off the line at the stop light just fine.
VERY happy with that gear combo.
I'll be duplicating it in my '62 K10.
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 09-03-2017, 06:33 PM   #13
LVPhotos
LVPhotos's Avatar
Heres another calculator with od at .70,
3.73 with od should be 2200rpm right in sweet spot
https://www.ringpinion.com/calculators/Calc_RPM.aspx
Old 09-03-2017, 06:49 PM   #14
rvrfoot
'65 LWB
- Go to a 700R4?
- Do both?
If you do the 700r4 you can leave the 373 rear end. If you do the rear end 308 or 325 will be good.
Old 09-03-2017, 07:14 PM   #15
65chevysub
65chevysub's Avatar
'65 LWB
- Go to a 700R4?
- Do both?
Man, I thought I had added a post and forgot about it. This is the exact issue I'm having. Hopefully I will get better power and mileage next year when I put in a 350. Should I stay with my 3:73's with the 350, and TH350? I know my truck weighs a ton and I don't expect to take off like a rocket, just a little more power and better mileage.
65chevysub is offline   Reply With Quote
Old 09-03-2017, 08:01 PM   #16
AcampoDave
AcampoDave's Avatar
I believe that for a straight forward, economical drivetrain it's hard to beat the reliability of a 350/TH350 combo mated to a 3.08. I know it's not glamorous but it's cost effective and it'll get you everywhere you ever want to go.
AcampoDave is offline   Reply With Quote
Old 09-03-2017, 08:40 PM   #17
rvrfoot
That is what i am shooting for.
Old 09-03-2017, 09:46 PM   #18
Brad54
Brad54's Avatar
Agreed.
-Brad
Old 09-03-2017, 11:39 PM   #19
Captainfab
60-66 Nut
With an non-overdrive trans, a 3.07 gear is a good choice for highway driving. With an overdrive trans a 3.42 or 3.73 gear is best.
Old 09-04-2017, 06:38 AM   #20
The Rocknrod
Moderator
The Rocknrod's Avatar
I went with a 3.42 rear gear while using a 200R4 trans so my tire size hopefully will about 27 inches and should keep her in the sweet spot at 70 MPH. Getting off the line should be awesome.
It could happen.
Old 09-04-2017, 12:07 PM   #21
rvrfoot
I will keep my 350 and just do my rear end gears.
Old 09-04-2017, 02:03 PM   #22
63burban
Chevy addict
Until you drive a 700r4 in an older vehicle you will never understand what it does for driveability.
Old 09-04-2017, 02:06 PM   #23
AcampoDave
AcampoDave's Avatar
You can still find five lug 3.08's on squarbodies in PickN'Pull. It's getting harder, but you still can. As for the 700r4, I have ridden in 2 differnt trucks which had them, but I guess they were poorly done because they just seemed to bumble around shifting oddly alternating from 3rd to 4th. Then 2 more guys I know fried theirs with the cable being botched up at the throttle. I'm sure they are fine when done properly but since I operate on the K.I.S.S principal, I pretty much wrote 'em off already.
Old 09-04-2017, 08:31 PM   #24
rvrfoot
I have 6 lug with nice rims. I heard if the 700r4 is not hooked right it will toast the trans.
Old 09-04-2017, 08:34 PM   #25
LVPhotos
LVPhotos's Avatar
https://www.google.com/amp/www.hotro...ion-build/amp/
The th 200 offers better gear ratios and .67 od vs .70 th700
rear end setup, transmission change
