Old 07-30-2017, 02:15 PM   #1
MIKESAD50
Wilwood Master Cylinder Recall
Not sure how many of you all out there are running a Wilwood 7/8" bore Master cylinder but got a Recall notice Friday.
If your running one, you might look into whether or not your included in the recalled list
1950 3100 5 window
MIKESAD50 is offline   Reply With Quote
Old 07-30-2017, 09:27 PM   #2
iowaboynca
iowaboynca's Avatar
Re: Wilwood Master Cylinder Recall
Thanks for the heads up...i have a clutch master and will check.
Build: "1950" GMC -Charlotte
iowaboynca is offline   Reply With Quote
Old 07-30-2017, 09:34 PM   #3
dwcsr
Hollister Road Co.
dwcsr's Avatar
this is the notice they sent dealer a few weeks ago
CAMARILLO, CA – Wilwood Engineering, Inc. of Camarillo, California has notified NHTSA of a defect in certain 7/8” bore Tandem Master Cylinders (with integral reservoir) and its intent to voluntarily rebuild or repair the affected parts. Wilwood® customers will be notified of this recall starting this month.
The voluntary recall is limited to the following part numbers:
260-9439
260-12900
261-13271 (with proportioning valve)
261-13272 (with proportioning valve)
These aftermarket master cylinders and kits are offered in different finishes indicated by a suffix (plain, black (“BK”) and ball burnished (“P”).
The part numbers above were distributed by Wilwood between January 2, 2006 and October 31, 2016. It is critical that affected customers contact Wilwood® if they are using a recalled certain 7/8” bore Tandem Master Cylinders (with integral reservoir) or know of someone who may have one of the recalled parts.
Consumer Contact:
Wilwood Customer Service
(805) 384-2270
7:30 a.m. to 4:30 p.m. PST, Mon-Fri
customercare@wilwood.com
For full details of the recall please visit http://www.wilwood.com/Pdf/Recalls/R...7E030-0986.pdf.
You can also visit the NHTSA website at safercar.gov.
dwcsr is offline   Reply With Quote
Old 07-30-2017, 11:45 PM   #4
tmoble
Dave @ Hollister
Have you heard anything about what is actually wrong with those masters?
tmoble is offline   Reply With Quote
Old 07-31-2017, 11:30 AM   #5
Rickysnickers
Rickysnickers's Avatar
Having a Wilwood on my truck as well, I did a quick search to find the issue and this website had the info, http://www.fourwheeler.com/news/1707...ter-cylinders/
Old 07-31-2017, 08:44 PM   #6
dwcsr
Hollister Road Co.
dwcsr's Avatar
Originally Posted by tmoble View Post
Dave @ Hollister
The seal in the front circuit can become deformed on some units making the front circuit fails allowing fluid to bypass the seal and possibly leaving no braking on that circuit. If you have one or know someone that uses wildwood masters let them know.
In short it puts the wide eyed, white knuckled , puckered thrill back into driving.
Old 07-31-2017, 09:27 PM   #7
tmoble
LOL, puckered WHAT?
Old 07-31-2017, 09:31 PM   #8
tmoble
that four wheeler article has actual info about the failure mode, first I've seen since this began.
I've seen a couple post that said Wilwood has been getting these units back for warranty for years, ignored the problem.
Old 08-06-2017, 08:53 PM   #9
vert1940
mine was involved in recall...called them, they gave me a UPS shipping slip...turn around is 2-3 business days...was notified Friday that the master cylinder is on the way back thru UPS and it did not cost me a dime...they were not forced to recall...yet...so far they are doing it on their own
vert1940 is offline   Reply With Quote
Old 02-18-2018, 03:09 PM   #10
Portmod7
Portmod7's Avatar
I am disappointed I didn't share this with everyone sooner, I just didn't think about it. A couple years ago mine actually failed. No warning, no nothing, pedal just went to the floor, NO brakes at all. Fortunately I was in a scenario where there was no harm done, it could have been very bad.
I sent my master off to Wilwood because I couldn't find ANYTHING wrong with my system or parts. They told me one of the seals had a little tear. I had them send the old parts back to me along with my rebuilt master, I couldn't tell anything from looking at the old seals. I think they charged me $100 or something for the rebuild.
Then, last year, I got the recall info. I checked with them, they said it was likely I got defective seals in the rebuild as well because they hadn't discovered the problem at that point. So I had to pull it off again, and sent it to them for rebuild. This time there was no charge AND the refunded my money for the last go around.
So anyway, I just wanted to get it out there that this is REAL, YES there have been failures. GET YOUR STUFF SENT BACK AND FIXED!
Super Blue - 1968 C-10 Short Stepside
Fastburn 385, 4-Speed Sag. on the Column, Coleman 9" Floater w/Detroit TrueTrac
Portmod7 is offline   Reply With Quote
Old 02-22-2018, 01:35 AM   #11
tmoble
what he said. Not always second chances on brake fails.
