Old 07-30-2017, 07:53 PM   #1
Leowalt
Post Alternator squeaking in 70 c/20
Need help finding the problem with the alternator in my 1979 c20
Probably just needs to be replaced but if you have any info let me know
Leowalt is offline   Reply With Quote
Old 07-30-2017, 08:05 PM   #2
AussieinNC
Moderator
AussieinNC's Avatar
Re: Alternator squeaking in 70 c/20
Check the belt tension first and condition of the belt...
Alternators usually don't squeak...
AussieinNC is offline   Reply With Quote
Old 07-30-2017, 08:51 PM   #3
bill3rail
bill3rail's Avatar
As Aussie said, Belts squeak, alternator bearings may squeak right before they seize up.
With the belt removed, is the alternator tough to turn?
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 07-30-2017, 09:02 PM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Try changing the tension on the belt, but before you do that, put a bar of soap against the belt while the engine is running. It will often silence (or at least change the sound of) a squeaking belt. Be careful not to damage any body parts, such as your fingers.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 07-31-2017, 02:20 PM   #5
57larry
take it to Auto Zone & have them test it
57larry is offline   Reply With Quote
#chevy #alternator #c20
