Old 08-03-2017, 12:15 PM   #1
Arnulfo
Clutch linkage hole in firewall 1970 C 20
Is there some kind of factory plug that covers the hole on automatics?
Arnulfo is offline   Reply With Quote
Old 08-03-2017, 02:44 PM   #2
FirstOwner69
FirstOwner69's Avatar
Re: Clutch linkage hole in firewall 1970 C 20
There were 2 types of plugs/covers used from '67 through '72. I believe the push-in plastic plug was used through 1970. After that, an oval steel plate with a screw at the top and bottom was used along with a gasket between the plate and firewall. The plastic plugs had a habit of popping out of the hole perhaps due to the pressure caused when the doors were closed.
Here's an old for sale thread showing the correct plastic plugs. Unfortunately, the seller hasn't been here since 10-15-16.
http://67-72chevytrucks.com/vboard/s...d.php?t=535199
EDIT: Added picture of the steel version with gasket and screws.
FirstOwner69 is offline   Reply With Quote
Old 08-03-2017, 02:49 PM   #3
dfwright
dfwright's Avatar
I don't know about the plastic insert, but the metal cover and gasket are repop'd
You can get one from Classicparts.com
(1967-81) Clutch Rod Firewall Delete Plate
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 08-03-2017, 05:15 PM   #4
Arnulfo
Many thanks for the info!
Old 11-17-2017, 11:35 AM   #5
old and rusty
Do these plugs go on from inside the cab or from the outside via the engine compartment?
old and rusty is offline   Reply With Quote
Old 11-17-2017, 12:16 PM   #6
cleszkie
cleszkie's Avatar
From the outside.
cleszkie is offline   Reply With Quote
Old 11-17-2017, 01:15 PM   #7
old and rusty
thanks, i guess i'll get me one.
