![]() Join Date: Oct 2009
Pic Request for factory two tone paint combo (RPO 65L)
Have found only a small handful of low-res or long-distance ref pics on some of the two-tone threads herein - please post an RPO 65L (65 Buckskin/75Mahogany) original paint truck if you can please. Thanks!
Re: Pic Request for factory two tone paint combo (RPO 65L)
Which paint scheme? (ie, ZY2, ZY3, ZY4, ZY5, ZY6).
Also - "L" = lower, or secondary paint color. "U" is upper/Primary color. Do you want the Mahogany to be the primary color, with the Buckskin as the secondary or inset color? K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
Thanks Keith, ZY3 - Buckskin pri with Mahogany inset. Would roof also be Mahogany in addition to the inset on ZY3?
EDIT: Disregard, I see that would be a Special two tone, so inset only. Last edited by jocko; 08-03-2017 at 06:27 PM. |
#4 | |
ZY3 is primary color up top and secondary color down low (roof is primary color), so I don't think we are quite on the same page just yet. Inset is ZY5. What model year ranges are you looking at? K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 08-03-2017 at 08:30 PM. |
1977. I have a 76 data book that I was referencing (same two tone codes as 77 I believe) and ZY3 was Special Two Tone - i.e. one main body color and the inset only being the 2nd color (so, roof in main body color, rather than inset color).
My assumption, based on interior & eng compartment paint is that the truck was originally main body buckskin with a mahogany inset - but the 65"L" from the SPID has me a little confused. The description matches what I would assume are pri/sec colors, but the L seems to indicate it would have had a Buckskin inset on a Mahogany truck(?) It's funny, the truck looks MUCH more like Santa Fe Tan than Buckskin. Not going to buy this thing, but doing a little research -it would have been a gem when new. Now it's repainted, maybe even more than I thought it was, and much of its originality mechanically/interior is long gone. Last edited by jocko; 08-03-2017 at 09:01 PM. |
77 colors below. so, the more I look at it, there's no way this truck just had the white changeover with the original main body left intact (but the interior, EVERYTHING is this color as in it sure looks like the original color (SF Tan) even if the exterior parts had a repaint. But neither color is Buckskin or Mahogany, now that I'm looking at it all side by side. So, I guess the remaining question is whether this was a Mahogany truck with a Buckskin insert (like Bvant's, pictured below - but they or may not be mahogany main body, not sure) - or Buckskin truck with a Mahogany insert (can't find a pic of this combo...
![]() Last edited by jocko; 08-03-2017 at 09:17 PM. |
Gotcha -
So the model year information makes all the difference - The Heritage Center documentation shows that you could get a Buckskin Primary and Mahogany inset (I would not have guessed that). The flip of that was not available (ie, you could not get a Mahogany truck with a Buckskin inset; it had to be Sante Fe Tan). Two caveats, FWIW - 1) It is really difficult to assess colors from photos on the computer, both because of the color shifts of the digitized photos themselves and then again because of the way they become represented on the computer screen. 2) In the assembly process the inset color was actually sprayed first. It was then masked off in the appropriate shape and the primary color sprayed over the whole truck. Removing the tape and masking reveals the intended two tone. Not sure if that helps but it might explain some of the overspray or layering patterns that you are seeing. K
got it Keith, thanks very much. So a Buckskin truck with a Mahogany inset. Woulda been a beaut originally. Any idea why there's an L on the combo code with the 65 rather than the 76? Thanks again.
#9 | |
I didn't start at truck until 1979 so I don't have first hand experience prior to that. K
No worries - thanks for sharing all your experience at the plant!
Not factory but heres mine....
1980 Silverado short bed 1993 GMC 1500 LS swap 2006 Lifted Z71 Crew Cab |
Cruzzzn' Vet
Another nice 83
