Old 08-04-2017, 02:52 PM   #1
MIDNIGHT711
63 c10 4.8 LS swap
So I've been a lurker on this of forum for a little while, been gathering info on this build and putting it to good use. Thank you for that.
Issue that we have come to is that we are using the dirty dingo motor mounts for are build, but have came to an issue with the headers fitting correctly. We are using the stock truck headers...any help on what to do? I've read that fbody will fit but haven't seen anyone do it with DD mounts
MIDNIGHT711 is offline   Reply With Quote
Old 08-04-2017, 11:51 PM   #2
dec010974
dec010974's Avatar
Re: 63 c10 4.8 LS swap
I think all c10 truck frames are different. I used a set of from ebay. speed engineering.
dec010974 is offline   Reply With Quote
Old 08-07-2017, 10:02 AM   #3
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Stock LS manifolds just won't work without cutting up your frame, TBSS manifolds work well and hooker has some shorties that work very well. These are budget ideas, you can go with Doug Thorley long tubes if you have the $
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 08-07-2017, 10:16 AM   #4
MIDNIGHT711
For the hooker headers is there a.specific thing to search for? Do I look up the donor truck or the c10...sorry for the noob question just tried searching and couldn't find so I'm thinking on doing it wrong
Old 08-07-2017, 10:50 AM   #5
MIDNIGHT711
Also can't do long tubes, truck is being bagged
Old 08-07-2017, 11:05 AM   #6
Clyde65
Clyde65's Avatar
https://m.summitracing.com/parts/hok...SABEgJxdvD_BwE
Clyde65
Rebuild of Clyde
support our troops!
Old 08-07-2017, 11:20 AM   #7
MIDNIGHT711
Thank you
