Old 08-05-2017, 09:49 AM   #1
DangerDan
Bad Brake proportioning (combination) Valve
My brand new proportioning valve is leaking out the front around the valve stem. NAPA part number NMC M552 does not specify if it is for Disc Disc or Disc Drum. I need a good Part number for a Disc Disc proportioning valve. Preferably NAPA so I can get it today. None of the Auto Zones - O'Reily's or Advance Auto even carry them. I see them on Summit and EBay.
DangerDan is offline   Reply With Quote
Old 08-05-2017, 09:53 AM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Bad Brake proportioning (combination) Valve
Power or manual brakes?
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 08-05-2017, 02:15 PM   #3
RichardJ
>>My brand new proportioning valve is leaking out the front around the valve stem.<<
You mean to say your Combination Valve is leaking from the Metering Valve stem.
NAPA NMC M552 is listed as used for '87-'93 and I don't know that any of those years had disc/disc brakes. Probably a disc/drum valve.
Is this a new rear disc installation that isn't yet operational? Before it leaked, did the combination valve work as needed?
CPP actually sells a Metering Valve replacement/repair part. Not sure it fits your NAPA valve. Yours might be loose, have dirt in it or need a new O-ring.
If this is a disc/disc setup of your own creation. you may want to use an adjustable Proportion Valve.
They sell stand-alone Prop Valves, but Wilwood, CPP and maybe others sell a switch/distribution block with adjustable Prop Valve build into it. Your Combination Valve is 3-in1. The Wiwood is 2-in-1
The Wilwood type unit will allow you to adjust for the needs of the disc/disc setup.
If you find that you need a Metering Valve, you can add a stand alone unit later.
You need a Metering Valve only if the brakes put your passenger through the windshield under low speed and light brake applications. Does the vehicle nose-dive while driving in a parking lot with relatively light brake application. A Metering Valve is sometimes called a Hold-Off Valve. It works only BELOW about 50 psi, which is little more than the weight of your foot will create.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 08-05-2017, 06:14 PM   #4
DangerDan
I found the correct combination valve AC Delco 171 1361 it is a disc Disc valve the NAPA Number you mentioned I had called on. It is a disc / drum unit. My entire system is new and they are power brakes. I looked at the Wilwood unit too.
I used the brake tool to block the spool when I was bleeding the system. I just got this truck on the road 8/2/17 so I guess I am in a debugging phase. I really have not driven it enough before discovering the leak to really know how it is performing as far as you nose diving question. I'll change the valve and go from there.
Thanks for your help.
Old 08-05-2017, 11:57 PM   #5
mike16
87-93? would that be metric?
mike16 is offline   Reply With Quote
