Old 08-05-2017, 04:15 PM   #1
N2TRUX
Happy to be here
N2TRUX's Avatar
Anyone running the Wilwood D154 rear disc with E brake?
Anyone running the Wilwood D154 rear disc kit. Its Wilwood #140-12569-DR rear disc kit with internal emergency brake. I have the Wolwood D52 calipers and rotors up front and Im considering this for the rear of Scarlett.
I'm curios how much better they perform than the stock 1.25" drums? Any input from someone with experience?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-05-2017, 05:19 PM   #2
Bobby Pootz
Bobby Pootz's Avatar
Re: Anyone running the Wilwood D154 rear disc with E brake?
I'm also curious, as I'd like to get disc's in the rear of my squarebody too.
What spindles are you using up front and how's the D52 compare to stock brakes? Thanks!
Rob
Bobby Pootz is offline   Reply With Quote
Old 08-05-2017, 08:12 PM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
Rob
Rob when I bought Scarlett she had vented rotors on front so I upgraded to Wilwood D52 dual piston calipers and braided stainless lines. At the same time I completely flushed the system and installed high temp fluid. The rear wheel cylinders were leaking so I rebuilt the rear brakes and installed new wheel cylinders.
I really haven't driven the truck enough to give an honest opinion on the improvement the calipers gave. I can say that they have performed well on previous trucks so I wasn't hesitant to upgrade again.
My 85 Sierra already has the 2.125" rear drums, which perform well. I know that the front brakes provide about 80% of stopping power. I can honestly say this is more about symmetry and aesthetics than performance gains. I just dont want to spend a grand and go backwards.
If your looking for real braking improvements, you need to step up to 13" or bigger rotors, and 4 piston calipers.
Articles-
"Refining Sierra"
Old 08-05-2017, 08:17 PM   #4
Bobby Pootz
Thanks for the info! I've seen your posts of the Scarlett build, it's a great thread and I'm slowly going through that.
I'm considering the 12.19" rotor 4 piston set up that Wilwood has, it's a bit spendy but good brakes on an old truck is worth it. I might consider the D52 replacement too. Looks like you've got a very capable truck! Thanks for the reply, it's much appreciated!
Rob
Old 08-06-2017, 01:06 AM   #5
PunishedC10
Subscribed!
PunishedC10 is offline   Reply With Quote
Old 09-17-2017, 05:16 PM   #6
Bobby Pootz
Bump to see if anyone else has rear disc brake feedback!
Happy Sunday!
Old 09-18-2017, 10:22 PM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
I'm in contact with a Wilwood rep now. I will let you know what I come up with.
Articles-
"Refining Sierra"
Old 09-19-2017, 06:24 AM   #8
Sik66
Should hit him up for a group buy!
Sik66 is offline   Reply With Quote
Old 09-19-2017, 10:42 AM   #9
1957 Chief
I have the 4 piston/12.19 rotors on the back of the truck. Bought it from Matt at MCB.
Had a few issues with the install on the axle tubes with the caliper clearance and centering. Other than that was a seamless install. I also have the 4 piston/12.19 rotors up front on the truck with a 1 inch bore MC and prop valve. With the prop valve screwed all the way clockwise, the rears still lock up under a panic brake application. I called wilwood and spoke with the engineers and he recommended that I put some gauges on the truck. Haven't been able to do that cause the truck got wadded up on the track.
Thats my input.
Bubba
1957 Chief is offline   Reply With Quote
Old 09-23-2017, 01:05 AM   #10
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Do they have these for a 3/4 ton?
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 10-04-2017, 03:16 AM   #11
mcmlxix
Collector of Projects
mcmlxix's Avatar
I would be interested to see the outcome ...
Rich
1972 K5 Blazer CST Click HERE
Old 10-05-2017, 07:36 PM   #12
68basket
Ive installed this rear setup on a customers 71 blazer. great quality kit, cant compare before and after as the blazer came in with blown out wheel cylinders. I have some pics somewhere
68basket is offline   Reply With Quote
Old 10-05-2017, 07:41 PM   #13
68basket
Found pics, let me know if you have any questions.
Old 10-05-2017, 07:42 PM   #14
68basket
Few more pics, I did new booster, master, prop valve, and front brakes also.
Old 10-14-2017, 08:45 PM   #15
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
Ken, any updates on this? I'd like to swap to rear discs, but as you know in TX we have to have an e-brake to pass inspection. I'd rather not have to register as a classic because I'd like to drive to work occasionally too.
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 11-01-2017, 05:43 AM   #16
mcmlxix
mcmlxix's Avatar
I would like to see this paired with a E-Stopp brake system...
https://www.estopp.com/
Rich
Old 11-02-2017, 06:21 AM   #17
D13
D13's Avatar
Hmm. Cannot apply ebrake with ignition power on.
So I come to a corner, brake pedal goes to the floor, I have to turn the truck off before this will allow activation of the e-brake? So how does this qualify as an ebrake?
Great parking brake though. Very nice package.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 03-18-2018, 07:22 AM   #18
Sik66
Hi.....does any one know if a std 15" c10 rim will fit with this rear disc kit?....or even with the d52 front caliper?
