Old 08-05-2017, 05:52 PM   #1
rockyrivermark
Pics of 71-72 proportioning valve needed
So I'm gone through everything in my braking system and still have some slight dragging up front, only after I've been driving a few min and things are hot.
It's looking like the proportioning valve which giving that truck sat for a few years I'm not surprised.
My truck is a 1970 which originally had 4 wheel drums. Previous owner upgraded 6-5 lug and hence I got front discs. Parts where from a donor 1971 c10.
Here's a pic of my proportioning valve.
Only one line for front and one for rear.
Please post a pic of your proportional valve from a 71 or 72.
I want to make sure I have the right one.
Thanks.
Replaced
Calipers
Calipers hose
Master cylinder
New pentosin super dot 4 fluid
Adjust booster to master rod
My build page
http://67-72chevytrucks.com/vboard/s...d.php?t=764662
My cabinet building site
http://www.cbcabinets.com
rockyrivermark is offline   Reply With Quote
Old 08-05-2017, 05:57 PM   #2
Mr Handy
Mr Handy's Avatar
Re: Pics of 71-72 proportioning valve needed
That is a distribution block for 70 and earlier. It is not a prop valve.
it looks like your master cylinder may also be for drum/drum is one reservoir bigger than the other?
Mr Handy is offline   Reply With Quote
Old 08-05-2017, 06:29 PM   #3
rockyrivermark
Ok. Thanks for the info. The master cylinder is new and I bought one for a '71 c10.
Back reaivoir is smaller
Old 08-05-2017, 07:01 PM   #4
notsolo
notsolo's Avatar
Here is a photo of a 71...72 is the same.
notsolo is offline   Reply With Quote
Old 08-05-2017, 11:36 PM   #5
LockDoc
The Older Generation
LockDoc's Avatar
If you are searching for one you might try typing in "Combination Valve" instead of "proportioning valve".
LockDoc
Leon
