Old 08-06-2017, 02:23 PM   #1
CG
BlahBlahBlah
Cab paint divider where there was none
So is putting a cab paint divider difficult when a cab didn't have one originally?
I still need to come up with one. It seems like they had some sort of spot welded mounting point thingies. Do you have to mount them this way or could a person use some sort of sticky back tape?
Interested in seeing how you have gone about this if you started with none originally.
Old 08-06-2017, 03:10 PM   #2
rockyrivermark
Re: Cab paint divider where there was none
There are small nylon clips that slide onto those studs. If your truck doesnt have the studs why not just use small screws to anchor the clips?
Prob need a #6 x 3/8". I can't recall if that part of the cab is double walled or not. I'll check.
Mark
My build page
http://67-72chevytrucks.com/vboard/s...d.php?t=764662
My cabinet building site
http://www.cbcabinets.com
rockyrivermark is offline   Reply With Quote
Old 08-06-2017, 04:23 PM   #3
NoNeck
NoNeck's Avatar
We installed a kit from LMC (I think) that came with the stainless trim, the plastic clips and tiny screws that need to be installed. After careful measuring we pulled a straight tape line and drilled the holes and put in the screws. Iit was a pretty simple installation, and really worked great.
POP
2016 RAM Laramie HEMI
1966 Fairlane GT/A, 390/335 HP
If it costs you a dollar to make a friend, KEEP THE DOLLAR.
If it costs you a friend to make a dollar, KEEP THE FRIEND.
NoNeck is offline   Reply With Quote
Old 08-06-2017, 04:32 PM   #4
FirstOwner69
FirstOwner69's Avatar
I have no experience with these, but this appears to be what you need.
Studs: https://www.classicindustries.com/sh...parts/?q=t1420
Clips: https://www.classicindustries.com/sh...parts/?q=T1419
Molding (includes clips): https://www.classicindustries.com/sh...arts/?q=t70868
FirstOwner69 is offline   Reply With Quote
Old 08-06-2017, 05:02 PM   #5
rockyrivermark
Yep. That's what you need. That's cool they sell them with screws. Once the clips are on the trim just snaps on. Little pressure with palm of hand and trim snaps right in place.
Old 08-06-2017, 05:46 PM   #6
CG
BlahBlahBlah
Ok, thanks guys. Just need to source an OEM set of moldings. I prefer using OEM whenever possible. May end up having to go with aftermarkets, we'll see =)
Old 08-06-2017, 11:49 PM   #7
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
The original mounting tits were spot welded on at the factory, and as has been mentioned, the nylon clips were used. If you use screws, make sure that you seal them somehow, so that any water that gets on them is repelled, as they will eventually let the body rust. Not a problem where I live here, in an irrigated desert.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 08-06-2017, 11:57 PM   #8
CG
BlahBlahBlah
Well we might get a teensy bit of rain up here in Washington State, so if this ends up happening Ill take your advice for sure.
Old 08-07-2017, 06:42 AM   #9
Zeroman
Zeroman's Avatar
I did not want to deal with the possibility of the screws leaking, and I wanted something different, so I had the trim airbrushed.....
Zeroman is offline   Reply With Quote
Old 08-07-2017, 06:48 AM   #10
CUSTOM/10
CUSTOM/10's Avatar
Most good body shops have a stud welding gun ( Used for pulling dents and such ) and can spot weld the tabs on just like the originals.
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 08-07-2017, 08:36 AM   #11
Grumpy old man
Grumpy old man's Avatar
The easiest way to install them is to position the trim and use multiple peices of masking tape . Once your happy with the position use a sharpened grease pencil / china marker , mark the top and bottom of the trim , remove the trim and center - mark and drill the holes for the clips and install the clips using pop rivits put the clip on the pop rivit and then position correctly and pop the rivit clip combination onto the truck ., They won't leak but you can dab a small amount of sealer to each hole if wanted .install the trim onto the clips top edge first and with a glancing palm strike snap the lower edge on . don't try to slide the trim onto the clips you'll take a chance of scratching your paint doing it that way . when removing factory install chrome divider using a non-marring tool pop the out side end of the trim off the clips and then slide the trim off by pulling to the outside of the truck . it's easy , it works and is also a repair option if you decide to install the screw type studs and strip out the holes .
Grumpy old man is offline   Reply With Quote
Old 08-07-2017, 08:43 AM   #12
CG
BlahBlahBlah
More great info, thanks!
The airbrushed trim looks great. I bet that was expensive.
Old 08-07-2017, 09:36 AM   #13
Hart_Rod
Hart_Rod's Avatar
Mar-K sells a great kit. All USA Made!
Hart_Rod is offline   Reply With Quote
