switch out carb on 64
have a 64 c10 with 292 engine. the carb is a one barrel rochester (or after market copy) never been to happy with it. anyone know of other carbs that bolt down to my manifold?
Re: switch out carb on 64
I put a Holley/weber from langdons stovebolt on my 230. It was a great carb but I never did get the choke dialed in. Nice that it's a progressive 2 barrel so you can get decent mileage if you want to.
It did require a baseplate adapter that he also sells. |
thanksDracko it looks a good site to find what i want
An early 80,s Rochester Monojet for a 292 is a good carb. It has electric choke. Or any 292 monojet with manual choke.
Try Daytona Parts. They provided me with a reconditioned stock Rochester for my 63 and it works great.
Posted via Mobile Device |
![]() Join Date: Jul 2016
I just replaced my rochester B with a carter yf model # 4371. I found it on ebay.
I havent driven the truck yet but it does idle nice. yf is supposed to give better mileage. i could get the rochester to run good for a while, then usually after one summer it would start to bog down and leak from the lid and need another rebuild, i got tired of that after 40 plus years of rebuilding it.
1965 Suburban, 2 wd.,292, 4-speed. proudly owned and operated since Valentines day 1969. |
I think the carb for the 292 if correct should have the same bore as the manifold at 1 5/8". 250's used a smaller bore carb at 1 9/16 on the same manifold.
We had a 292 in a 67 1 ton and I don't remember any carb problems. It burned lots of gas but then again it was a work truck with a heavy dump box. Lot's of torque in those engines. |
![]() Join Date: Mar 2013
Monojet or a 500 cfm holley 2 barrel with a 2 to 1 adapter will work nicely.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
| Bookmarks |
