Old 08-08-2017, 02:45 AM   #1
ShortCST
ShortCST's Avatar
D52 Brake Pad Recommendations? Want The Most Bite
I'm fairly certain that this is a loaded question. But for street use on a 3600lb pickup, what pads have you used that transformed bite/pedal feel?
I have new dual 2.0" piston Wilwood calipers with stainless hoses and the existing vacuum booster from the factory boosted discs. My new dual master cylinder is of the 1 1/8" large port variety. My tires are 235/75R15, and I'm lowered 2" (not sure that last bit matters for bite and pedal feel).
I'm not concerned about brake dust, as I'm running 15" steel wheels with dog dishes. I've read that dust isn't much of an issue with the new high-performance compounds, anyway.
I just want to be able to stand the truck on its nose, without standing on the pedal with both feet.
ShortCST is offline   Reply With Quote
Old 08-08-2017, 05:03 AM   #2
NC_John
NC_John's Avatar
Re: D52 Brake Pad Recommendations? Want The Most Bite
Contact wilwood - they have multiple pads available for these calipers. Tell tech what you are running and they'll give you their recommendation. That was the direction i went for my entire front brake setup and am very happy with how it performs.
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
Old 08-08-2017, 05:35 AM   #3
nds1968
nds1968's Avatar
Rob from No LImit did a test run on front pads. Try and search his threads, I believe he liked Hawk pads. I don't remember the details though as some stop well but we're noisy ect...
Nate
1967 short fleet Project Blue Goose
'If it don't bounce back... heeheehee you go hungry!" Blues Brothers
nds1968 is offline   Reply With Quote
Old 08-08-2017, 12:54 PM   #4
ShortCST
ShortCST's Avatar
Thanks John, I'll do that.
Old 08-08-2017, 12:54 PM   #5
ShortCST
ShortCST's Avatar
Thanks Nate. Do you know his username?
Old 08-08-2017, 03:26 PM   #6
68Stepbed
68Stepbed's Avatar
I had Hawk pads on mine for a couple years. They most certainly "bite" like crazy, but keep in mind, they're noisy as well as dusty. Wilwood does offer different compounds also. I'm considering going to a slightly more aggressive pad with my new Wilwood setup.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 08-08-2017, 03:49 PM   #7
Overdriven
So you want to be able to stand it on its nose multiple times in a row? Or just looking for better pedal feel and bite for those more rare times you need to stand it on its nose? When talking with a company like Willwood they'd likely ask but if they don't you should mention it.
You might also want to check your rear drums if so equipped. You'd be surprised how much difference in pedal feel can be had by tightening up the rear drums.
I've been running EBC Yellow pads and EBC rotors on my daily driver Tacoma and they made a world of difference in pedal feel and bite. I can stand on them way more times in a row before getting a hint of fade which was another area I wanted to address. I do need to be careful when they're cold though, first thing in the morning isn't bad. But go bombing down the interstate without touching the brakes for a few hours and it's surprising how little they do, especially if you're late braking that off ramp. EBC Green offered modest improvements in allmareas without the decrease in cold performance but just wasn't agressive enough. Hope this helps.
Overdriven is offline   Reply With Quote
Old 08-08-2017, 04:19 PM   #8
halfstep
I was getting ready to post to "For Sale" section...
NIB (new in box) set of Hawk pads for your application.
Highly regarded and recommended by NoLimit.
If you are interested, PM me or look in for sale area later.
halfstep is offline   Reply With Quote
Old 08-08-2017, 04:56 PM   #9
nds1968
nds1968's Avatar
Not sure if the info was in this thread http://67-72chevytrucks.com/vboard/s...d.php?t=419251
Nate
Old 08-09-2017, 04:27 PM   #10
68Stepbed
68Stepbed's Avatar
Those will certainly do what you're saying you want.
Matt
