Old 10-26-2003, 09:42 AM   #1
special70gmc
special70gmc's Avatar
why is my truck higher on one side?
after i did all the suspention work(discks,dropped spindals,2'' drop springs) i didnt notice ant difference between the two but now that the engines in the pass side is higher than the drivers. I cant figure out why, anybody have any ideas? thanks -kyle
1986 c-10 swb 5/7 drop 20'' coys
1958 belair 2door
special70gmc is offline   Reply With Quote
Old 10-26-2003, 09:42 AM   #2
special70gmc
passerger side
1958 belair 2door
Old 10-26-2003, 09:44 AM   #3
special70gmc
i jusy cant resist posting this pic. i know u've all seen it before but..................
1958 belair 2door
Old 10-26-2003, 10:33 AM   #4
Gee_Emm
double check to make sure the spring is in the pocket in the a arm
Gee_Emm is offline   Reply With Quote
Old 10-26-2003, 11:16 AM   #5
Primered_69
Primered_69's Avatar
I do not know what your problem is but could we see some more pictures of the outside of your truck.
I like what I have seen so far. You got a good looking truck. What else are you going to do.
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together)
Primered_69 is offline   Reply With Quote
Old 10-26-2003, 12:14 PM   #6
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I have seen this happen if you tightened bolts with the truck in the air.The suspension should be under load for final torquing.Maybe you did one side in the air and the other on the ground.The spring pocket is probably the most likely problem. Let us know what you find so everyone else can avoid the prob.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 10-26-2003, 02:30 PM   #7
Dean23
68cst_ss490
Dean23's Avatar
maybe u parked it up on the curb on one side...lol. i would try loosening the suspension off and then retorque it under load.
Dean
edmonton,canada
a winter wonderland
2005 Chevrolet Avalanche LT
cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers.
http://www.cardomain.com/ride/3090973
Dean23 is offline   Reply With Quote
Old 10-26-2003, 03:17 PM   #8
casey
casey's Avatar
If all else fails try swapping the springs, maybe there tempered differently, I had a spring shop put in two new front springs one time and they ended up shimming one spring, cause they compressed differently
casey is offline   Reply With Quote
Old 10-26-2003, 06:44 PM   #9
special70gmc
what parts should i re torque the ball joints or the a-arms? i tried to redo the spring bout a month ago but i can see if is set right or not. here pics...the 31'' monster tires really have to go soon -kyle
1958 belair 2door
Old 10-26-2003, 06:47 PM   #10
Dean23
68cst_ss490
Dean23's Avatar
i would try the control arms
Dean
edmonton,canada
a winter wonderland
Old 10-26-2003, 06:48 PM   #11
special70gmc
2
1958 belair 2door
Old 10-26-2003, 08:20 PM   #12
67cst
i love summertime
67cst's Avatar
how much are we a talking here? didnt someone ask this a while ago and it turned out being the battery making the difference?
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 10-26-2003, 10:29 PM   #13
special70gmc
bout an inch or so......
1958 belair 2door
Old 10-26-2003, 10:57 PM   #14
Gee_Emm
Battery? Wouldnt the master cylinder, steering column and all that other stuff equal it out?
Old 10-26-2003, 11:06 PM   #15
MandarinSixSeven
Seasonal Poster
MandarinSixSeven's Avatar
ya mine did that at first really bad, it turned out all I had to do was lift up the one side and turn the spring so it was lined up with the little notch/pocket in the a-arm...there is a little indent that the end of the coil has to butt up against.
67 GMC Short Step
350/4-Speed/3.08 Posi
Front/Rear Sway Bars
Kelowna BC, Canada
Member of DTPW
MandarinSixSeven is offline   Reply With Quote
Old 10-26-2003, 11:07 PM   #16
MandarinSixSeven
Seasonal Poster
still mine sits a little bit higher on the drivers side too...don't know why
67 GMC Short Step
Kelowna BC, Canada
Member of DTPW
Old 10-26-2003, 11:41 PM   #17
Alexis
Member since 2000
Alexis's Avatar
check to make sure all your balljoints are seated in right. Also check to make sure the springs are aligned right. check the spindle and see if there is any differance in the way the ball joints sit in them also.
Alexis is offline   Reply With Quote
