Old 08-08-2017, 08:59 PM   #1
68gmcdude
250cid Choke to Carb Connection
Hi... The cable for my choke is not connected to my Rochester Monojet carb on my 250cid motor. Looks like I am missing the piece to connect it. Can someone please post a pic of how it should be connected? Thanks!
68gmcdude is offline   Reply With Quote
Old 08-08-2017, 10:05 PM   #2
bill3rail
bill3rail's Avatar
Re: 250cid Choke to Carb Connection
If the choke arm has a hole in it, the cable needs a Z bend on the end to slide it in.
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 08-08-2017, 10:57 PM   #3
68gmcdude
Thanks bill3rail...
Old 08-09-2017, 08:19 AM   #4
bill3rail
bill3rail's Avatar
You are welcome.
Does the choke arm have a hole in it?
Old 08-09-2017, 09:45 AM   #5
68gmcdude
Yep... There's a hole in it. I was thinking the hole was for another piece that was missing. I'm assuming the end of the cable must have broken off.Thanks!
Old 08-09-2017, 10:22 AM   #6
VetteVet
Msgt USAF Ret
VetteVet's Avatar
There is a cable attachment sold by Dorman that Autozone should carry.
The cable goes through the small hole and the screw goes through the bracket on the carb and threads into the attachment to hold the cable to the carb.
This lets you attach the cable and it allows you to adjust the length.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 08-09-2017, 09:59 PM   #7
bill3rail
bill3rail's Avatar
Attachment 1678695
Much simpler than my way!
