New 20" wheels Bore size to small (Help)
Hey Guys, Just got my new 20" wheels and the bore size is a tad to small on the wheel about 1/16"th both front & back, not sure what to do? do i shave down the wheel or the truck side?? They will fit its just that last little bit, any advice would be nice..
Re: New 20" wheels Bore size to small (Help)
for my torq thrust st wheels, I used a router with a wood bit and opened the wheel bore a 1/2 inch. I used conical lug nuts to center the wheels. Keep in mind, the wood bit worked fine on the aluminum wheel and I picked up the the wheels used for a couple hundred bucks. Not sure I could do it on new expensive stock.
Take the rotors off and find someone with a lathe that can turn down that casting to the right size. I have done this before and it works great.
