LS Swap AC Compressor Question
I have a 79 C10 with a 5.3 LS Swap and I want to mount the AC Compressor down low in the factory position but the motor mount is in the way. I know it can be modified to make it fit. I just wanted to ask and see if anyone has installed the Trans-Dapt Performance Engine Swap Motor Mounts 4205
Thanks |
Re: LS Swap AC Compressor Question
and the frame needs cut/modifyed also and not just a little.
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
#4 | |
Posted via Mobile Device |
factory look with 80/90's style comp from our trucks.
https://www.holley.com/products/acce...y/parts/20-131
I personally have been looking at passenger side high mount Sanden compressor options. The compressor is way more effiecent and is smaller then the R4 style
1964 Coupe Deville(cruiser) 1966 Chevy II Nova 2door Hardtop 1985 C10 LS1/4l80e, Ridetech coilovers,22”Coys 2019 F-250 Platinum-Deleted/Carli Supension 37” MT’s 2000 Trans Am WS6, LS1/T-56, too many mods to list |
Proud Vet that loves the USA
![]() Join Date: Jun 2016
I put an LS in my son's 84 truck. I notched the frame where the compressor lines exit.
For the motor mount, I pulled the frame mount off the truck and extended it a little but. Then redrilled the motor mount holes. Like was said earlier, lots of info in the LS swap forum on this site. I would also install a trianary switch for the fans unless you have your computer sending input to them from the AC control. If you need pics just PM me and ill text em to you. Bubba I still use the factory condenser core, accumulator and evap core. Truck blows frost out the vents. |
#8 | |
#9 | |
