Old 08-11-2017, 02:04 PM   #1
1970ChevC10
1970ChevC10's Avatar
1970 C10 SB 350 to BB 396 Swap
Bought a '67 396 BB for my C10, is it necessary to change my front springs? What other possible hurdles do I face?
1970ChevC10 is offline   Reply With Quote
Old 08-11-2017, 02:19 PM   #2
demian5
demian5's Avatar
Re: 1970 C10 SB 350 to BB 396 Swap
It will lower it and its up to you if you want to change them.
Cooling will be the big one.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 08-11-2017, 04:28 PM   #3
1970ChevC10
Was also thinking of swapping my TH350 for a Richmond T-10 4 speed. Anybody else try this before? Will that tranny hold up to the 396 that will be installed?
Old 08-11-2017, 06:00 PM   #4
RenoKeene
Florida Edition
RenoKeene's Avatar
Factory 1/2 ton big blocks came with stock 3/4 ton front springs to carry the extra weight. I used new stock 3/4 springs and cut 1/2 of a coil off to get the height I wanted (along with 2 1/2" drop spindles) and still retain the strength.
You'll also need a 4 row radiator as been mentioned and if you haven't upgraded your front brakes to disk I would do that too. Engine stands are different also.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 08-11-2017, 07:37 PM   #5
Boog
laying low
Boog's Avatar
I imagine you will need all different accessory brackets too. Power steering pump with remote reservoir.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 08-12-2017, 02:08 PM   #6
70STOVEBOLT
70STOVEBOLT's Avatar
You do not need to replace the front coils. My '70 had a 250 in it and I put in a 402 and did not change the springs. The ride height is the same as before. You will need engine stands as mentioned but the 350 mounts will work and are much less expensive than the big block mounts. I had to move the automatic transmission crossmember back to the rear mounting holes and shorten the driveshaft but you should not need to do that. Also you do not need a 4-core radiator unless you have air or will be towing with it. I have a 3-core and it keeps it plenty cool. The engine is stock with a mild cam and an Edelbrock 750 carb with HEI. You will need a big block fan shroud however.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
