Old 08-12-2017, 10:28 AM   #1
weim55
ID OE Blazer Doors?
Is this correct to a 69 to 71 door? I was stunned at how crude they produced these. Is there some sort of cover that goes on top of the vent frame and edge door sill?
Thanks, Steve
weim55 is offline   Reply With Quote
Old 08-12-2017, 10:30 AM   #2
weim55
Re: ID OE Blazer Doors?
Pic 2
Old 08-12-2017, 11:55 AM   #3
briank
Hard to tell from those pics if they're correct for those years.Need to see inside of the door to see if there is a plastic or a metal ferrule and screw...but those doors are crude from the factory. There is a weatherstrip type channel that slides down into the door that will cover the one cut then there is another plastic piece to cap by the top of the vent window.
briank is offline   Reply With Quote
Old 08-12-2017, 12:51 PM   #4
1rippen6
Doesn't look like it has the reinforcement for the latch which should be spotwelded in may be a truck door cut down.
1rippen6 is offline   Reply With Quote
Old 08-12-2017, 02:31 PM   #5
DaHos
DaHos's Avatar
^^^^^^^^ Same thing I saw.........cut truck doors
And yes, there should be a cap that covers the top.
1967 C10 SWB
Owner - Rustbelt Restorations
DaHos is offline   Reply With Quote
Old 08-12-2017, 05:19 PM   #6
Mike C
Mike C's Avatar
Factory Blazer doors were cut truck doors too. At least that's what my Jimmy looked like when I re-did the doors 25 years ago. With some latch reinforcement added. The cap on the back of the door is molded into the rear window guide rubber.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
