Old 08-13-2017, 10:42 PM   #1
rvrfoot
283 starter problems.
I have a 283 motor that had a powerglide trans. I want to put a 350 trans on it. My problem is a got a mimi starter. It will not line up with the holes on the bottom of the block.
rvrfoot is offline   Reply With Quote
Old 08-13-2017, 11:13 PM   #2
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: 283 starter problems.
Originally Posted by rvrfoot View Post
I have a 283 motor that had a powerglide trans. I want to put a 350 trans on it. My problem is a got a mimi starter. It will line up with the holes on the bottom of the block.
I wouldn't think it should be any different from a powerglide to a Th350.
66 C20 Service Truck:
Old 08-13-2017, 11:24 PM   #3
rvrfoot
I dont think so ether. But the mimi starter dont bolt up to the block.
Old 08-13-2017, 11:56 PM   #4
Captainfab
60-66 Nut
You have contradicting statements here. The trans does not change anything about how the started bolts up to the block as long as you are using the same diameter/tooth count flexplate.
Old 08-14-2017, 12:01 AM   #5
rvrfoot
The starter will not line up with the holes on the block.
Old 08-14-2017, 12:24 AM   #6
Captainfab
60-66 Nut
Does your mini started have only the staggered bolt holes and your block have the straight across holes? If so, you'll just have to get a starter that has the correct straight across bolt holes to match the block. Some of the older blocks were not machined for both style of starters. Didn't you already have a starter on the block with the powerglide?
Old 08-14-2017, 12:28 AM   #7
rvrfoot
The holes on the block is straight as well as the starter. I will post pictures on monday.
Old 08-14-2017, 12:42 AM   #8
Warrens69GMC
Warrens69GMC's Avatar
I remember 1 of the mini starters wont bolt up because it needs to be rotated on the starter body to be able to line up to the holes. Is the started solenoid preventing the starter from lining up correctly?
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 08-14-2017, 12:44 AM   #9
rvrfoot
No the bolt hole is off about 1/4. One goes in and the other is off.
Old 08-14-2017, 12:47 AM   #10
rvrfoot
I got the hitachi mimi starter part number pls 100. It was $163
Old 08-14-2017, 06:43 PM   #11
Kudzupatch
Kudzupatch's Avatar
Sounds like you have the wrong starter but not sure what that has to do with the transmission?
Kudzupatch is offline   Reply With Quote
Old 08-14-2017, 07:51 PM   #12
rvrfoot
Because someone will ask me that question. Thats why i said what trans i will be running. The old starter bolted to the old trans.
Old 08-18-2017, 01:21 PM   #13
rvrfoot
Will be returning the mimi starter. I will keep searching for the right answer.
Old 08-18-2017, 09:05 PM   #14
nonstop
So what year is the engine and truck? Was it a cast iron Powerglide?
nonstop is offline   Reply With Quote
Old 08-18-2017, 09:09 PM   #15
rvrfoot
Its from a 61 impala 283 cast iron powerglide
Old 09-06-2017, 09:55 PM   #16
YoungPup1977
Why would you buy a mini starter for 163 bucks when you can get a plain ole GM starter that costs a lot less...the 283 engine rebuilt or is it used ? The GM starters have different noses on them, just know which flexplate you are going to buy....168 tooth or 153 tooth....you said you were installing a TH350, did it come with a TC and flexplate ? Make sure the starter matches up with the flexplate as well.... the 153 tooth flexplate is smaller in diameter so the nose on the starter will be different than a 168 tooth flexplate......
ONe more question, will a flexplate that bolts to th350 TC bolt up to the 1961 283 crank ?
Good Luck !!!!!
YoungPup1977 is offline   Reply With Quote
Old 09-06-2017, 11:04 PM   #17
rvrfoot
Good Luck !!!!!
I wanted a mini starter because i will install headers. The 283 just got rebuilt. The th350 did not come with a flexplate. I just found out the mini starter did not fit because the 283 motor is a 1958 to a 1962 thats why.
