Old 08-14-2017, 03:58 PM   #1
WB72
Before and After
WB72's Avatar
LS wiring Harness layout
I have a 2002 5.3l LM7 truck engine that I am going to install in my 67.
I purchased a bunch of parts, so I don't have the donor truck to reference the layout of the wiring harness. Surprisingly, there isn't a lot of information about this online.
Is there a rough diagram on where the harness lays on the engine?
Where is the PCM located on this?
What position does the harness enter the engine?
Does it wrap around the front, how does it go to the bottom of the oil pan?
If anyone has pics of this in their build thread, let me know where I can look.
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
Old 08-14-2017, 05:03 PM   #2
rctrooper1
Re: LS wiring Harness layout
the original harness will come out from the driver side over the valve cover and the pcm is located on the driver side wheel well. once you modify the harness you may opt to change where you want the pcm located.
rctrooper1 is offline   Reply With Quote
Old 08-14-2017, 07:33 PM   #3
WB72
Before and After
WB72's Avatar
I will start with that, Thanks. to get to the Passenger side, does the rest of the harness go around in the front or rear of the engine?
For starters, I would like to get it laying in its stock configuration.
66,000 miles.
Alberta, CANADA
Old 08-15-2017, 12:09 PM   #4
snipescastle2
snipescastle2's Avatar
Talking Re: LS wiring Harness layout
Check out this website;
http://lt1swap.com
He has most up to date info on the specific LS/Vortec pin outs and pcms to use,etc... lots of good info on how to do your own "wire diet" there are many YouTube videos that explain how to do this with four wire hook up, but you will still need to re program the pcm to remove VATs (anti theft system) other than that, he also does pcm programming too!
Hth,
Ben
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time"
“Serious Black” my 1971 Short Bed Fleetside Sold to
an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten”
snipescastle2 is offline   Reply With Quote
Old 08-15-2017, 01:53 PM   #5
WB72
Before and After
WB72's Avatar
http://lt1swap.com
Hth,
Ben
Yes, Brandon has a great site. I am looking for the basic where the loom sits on the engine.
66,000 miles.
Alberta, CANADA
Old 08-15-2017, 03:51 PM   #6
Korted
The main starter wire follows the oil pan from starter to balancer, then across to the drivers side, and up to a red connection that bolts to the front accessory mount. The top part of the harness forms a "U" on top of the engine (it's actually an "n" if you're standing in front of the engine), with the coil and injector plugs parallel to each other. The cam position and oil sensor are in the back. Trans connections branch off at head 7 (drivers rear) close to these. AC , coolant level, and passenger O2 are the longest leads, and branch from the "n" about head 8(passenger rear). If I remember correctly, the oil pressure and cam position are unique plugs - you cannot find another sensor that uses the same plug type. Worst case, lay the two groups of injector plugs parallel to each other. These two groups of four connect to each other at the rear of the engine.
Korted is offline   Reply With Quote
Old 08-15-2017, 04:52 PM   #7
chooch
Front to the left.
chooch is offline   Reply With Quote
Old 08-15-2017, 05:09 PM   #8
Korted
Nice! Is this 2002, or newer? I don't know when they switched to three connectors on the ECM. 2001 only had two.
Old 08-15-2017, 05:31 PM   #9
67 chevelle
67 chevelle's Avatar
photobucket sucks now
I have a picture for you anyone have a clue how i can get it to you ?
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 08-15-2017, 05:48 PM   #10
67 chevelle
figured it out , just put it in my album on here
the harness above is for like 2015 and newer
