Old 08-15-2017, 07:50 AM   #1
jrthe1
jrthe1's Avatar
Squeaky Clutch Pedal Fix
My clutch pedal squeaks in both directions and is quite annoying. I've sprayed WD40 everywhere I could think of to no avail. Looking for an easy fix.
Thanks.
jrthe1 is offline   Reply With Quote
Old 08-15-2017, 09:26 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Squeaky Clutch Pedal Fix
To do it right you should remove the pedals and look at the bushings, maybe grease them.
Old 08-17-2017, 07:31 AM   #3
jrthe1
jrthe1's Avatar
Thanks Rocknrod. Makes sense.
Old 08-18-2017, 02:05 PM   #4
rvrfoot
Change it to a auto. Sorry just had to say that.
rvrfoot is offline   Reply With Quote
Old 08-18-2017, 02:17 PM   #5
The Rocknrod
Moderator
Thats what I am doing.
Also there is a little rubber bumper the arm hits when not depressed, that may be gone and causing a squeak.
Old 08-19-2017, 08:40 PM   #6
Backpayne
Thanks.
Oh my goodness. Mine just started doing this. Time to look at those bushings!
Backpayne is offline   Reply With Quote
Old 08-19-2017, 08:59 PM   #7
padresag
it can come from anywhere in the linkage inc. the zbar. wear in the linkage connections and lack of grease in the zbar
ron
padresag is offline   Reply With Quote
