Old 10-26-2003, 04:44 PM   #1
tim m
What type of block
Is there any way to find out if I have 2 or 4 bolt main, wihtout taking the oil pan off?
1970 k10
1971 C10
Gilbert Az
tim m is offline   Reply With Quote
Old 10-26-2003, 04:44 PM   #2
cableguy0
usually the only sure fire dead on way is to pull the pan and look
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 10-26-2003, 07:34 PM   #3
Green72GMC
Green72GMC's Avatar
get the block # and go to http://www.mortec.com/castnum.htm
1972 GMC SWB, 305 powered
1980 diesel VW pickup, Needs a Heart Transplant
1997 Toyota Taco
The Second Amendment is in place incase they ignore the
others.
Green72GMC is offline   Reply With Quote
Old 10-26-2003, 08:02 PM   #4
cableguy0
but even still some casting numbers could be either 2 or 4 bolt the only sure fire way is to pull the pan. if the engine is running good or in a truck it doesnt matter much anyways a 2 bolt is plenty strong for about any street bound motor. and in some cases the 2 bolt is stronger than the 4 bolt
Old 10-26-2003, 09:49 PM   #5
Scott Johnson
Junior Member
Scott Johnson's Avatar
I think if the last 4 numbers are 0010, it`s a four bolt.
71 C10 Step Daily Driver
72 K10 Suburban Work in Progress
www.louisianaclassictruckclub.com
Scott Johnson is offline   Reply With Quote
Old 10-26-2003, 09:53 PM   #6
Z28Owner
Z28Owner's Avatar
My spare 350 is 0010 and its a 2 bolt, but you can get a 2 bolt Splayed at the machine shop and its supposedly stronger than a 4 bolt.
1971 LWB Chevy C-10
350/350 3:42 eaton
Z28Owner is offline   Reply With Quote
Old 10-26-2003, 10:25 PM   #7
crazy longhorn
Fabricate till you "puke"
3970010 is a very common block, and can be 2 or 4 bolt.....the 1 in my Longhorn is a 2 bolt block(also 10/20 high nickel). i also have 2 spare blocks with the same casting # , & they are also 2 bolt blocks. the best way to know for sure, is pull the pan ,as cableguy suggested i also agree that the 2 bolt block is plenty strong for a hot street application.....with addition of a set of main studs, the 2 bolt block should handle in the range of 450hp. for the ultimate 4 bolt, a 2 bolt with a splayed cap conversion is the ticket. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 10-26-2003, 10:26 PM   #8
bigjimzlll
bigjimzlll's Avatar
Ive owned 4 0010 blocks...all were 2 bolts
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 10-26-2003, 10:36 PM   #9
cableguy0
i will let you guys know how much a bolt will handle when i get the brodix track 1's and switch to a roller cam setup motor will be making over 500 ponies on the motor then im gonna spray the he!! out of it so i will let y'all know in a few months when im finished how long it takes to break the 2 bolt and snap the crank in half
Old 10-26-2003, 11:19 PM   #10
Scott Johnson
Junior Member
Guess I got lucky, my 0010 is a 4 bolt. I was told that 0010`s were all 4 bolts, wan`t sure that`s why I said "I think".
Old 10-26-2003, 11:43 PM   #11
bigjimzlll
bigjimzlll's Avatar
yea..I think im just unlucky with the 0010 blocks..I heard over half have 4 bolts
Anderson,CA
Old 10-26-2003, 11:47 PM   #12
Scott Johnson
Junior Member
I guess cableguy is right, the only sure way to tell is remove the oil pan.
Old 10-26-2003, 11:49 PM   #13
cableguy0
yea jim i have had 3 010 block that are 2 bolt and in the machine shop i work in have seen who knows how many that are also 2 bolt so im thinking its less than half that are 4 bolts
