Door seal problem
I put new door seals on my 65 but now it's really hard to shut the doors. Anyone else have this problem? If so what did you do to correct it ?
![]() Join Date: Sep 2002
Re: Door seal problem
Common problem on just about every aftermarket weatherstripping, cars or trucks. Usually, buying the softest available helps. But, short of experimenting with every brand out there, try this:
I strategically bent the pinchweld inward slightly to allow the rubber to just touch the door. I did this during the mock-up stage before paint so I wouldn't have to worry about damaging the paint. |
I know it's a little late now but the absolute best solution for door weatherstripping on our C-10's is off a 2006 Honda Civic. Check out this link:
http://67-72chevytrucks.com/vboard/s...d.php?t=617703 |
#4 | |
Never Ending Projects
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
![]() Join Date: Oct 2006
I used press on seals and had zero issues . Door closes solid.
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
I just got the ones from lmc the push on ones. Will see what happens.
It's Better With Nitro
I've used the Honda seal and most recently the press on seals from Precision. Both are far superior to glue-ons that many of us have struggled with in the past. I would get the Precision seals.
Them are the ones i got. Every one said there the best.
I have the push on ones from Brothers truck. They work great and the door shuts easy just like factory.
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
Im ordering a set from Prescott Honda tomorrow. Got my door jambs stripped and primered yesterday and dont want to use glue again.
Changed my mind and ordered a set from Brothers last night. $30 cheaper for the set. Last edited by 65chevysub; 08-21-2017 at 06:34 AM. Reason: adding text |
http://67-72chevytrucks.com/vboard/s...d.php?t=721217
I have no issues with Precision push on seals.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
#12 | |
Moderator
![]() ![]() Join Date: Aug 2011
#13 |
Its hard to keep up with these young kids. lol
#14 |
what is the website for GMCPaul's? I tried to do a search and it came up with every GMC dealer with the name Paul in it and thats all
Thanks |
#15 |
What part are you looking for?
#16 |
Moderator
#17 | |
http://www.gmcpauls.com/60-66_exterior.htm |
#18 |
Your going to love them!
#19 | |
#20 |
I used the Honda seals...love them...love them...doors still close easy...
1990 Silverado Sport 2010 Silverado K1500 1996 K2500 |
#21 |
#22 |
Thanks for the info guys. I wish I had known about the Honda seals before I bought the ones I have.
#23 |
