Fuel Pump Failure?
Last night I filled up the tank(wasn't on empty nor ever has been) and I started it. While it was idling I was putting some music on and it died. Looked and the filter was completely empty.
With a little starter fluid I got it to run and when I was back home, only a quarter mile, it was full again. Has been hard to start the past couple days and I think it wasn't getting fuel(pumped the throttle and couldn't hear fuel coming out). Took this video of it today and something seems strange. Fuel pump bad? Hole in the hose? Something clogged in the tank or pump? Normal? I'm stumped, hope one of you have an idea. Thank you all! https://www.youtube.com/watch?v=n9wTGmOn-7o |
Moderator
![]() Join Date: Jun 2017
Re: Fuel Pump Failure?
Those erratic pumps of gas thru that filter could be a pump about to die...
It could also be a sticky needle and seat not letting the fuel to flow thru correctly... Am assuming this has a mechanical pump... I usually prefer to use an electric pusher pump and route the fuel lines away from as much heat as possible. If you have one, put a fuel pressure gauge in the line between the pump and carb...you should see around 5 psi,,,any less and you have found your issue. ![]() ![]() ![]() |
the same symptoms in my truck were caused by rust coming from the gas tank
